Question about Nokia 7610
"Connection Error" - Nokia 7610
From the past 4 days I am getting 'Connection Error' Message, whenver I tried calling someone. However, the SIM Card seems perfect (It is working on other phones). I tried to solve this on my own, but couldn't. Please help me in resolving this problem. I contacted the service provider and there is no problem from their side too.
-Kishore
  • gladikishore Mar 27, 2008
    Hi Shevng,
    Thanks a ton for your help. The phone is working now and am very happy with your reply.
    Great going..
    Kishore
  • 175 Answers
Hi there did you try to reset the phone? but first must backup the phone contact. now to reset the phone just input the code: *#7370#.
then if the problem still the same. final is to format the phone, no problem cuz' you can manually format that phone by holding 4 keys. here's the trick
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till FORMATING appears then release after formating finish phone will be ok. DONE
ok!
peace!
Posted on Mar 26, 2008
7610 supernova locked code
Hi what kind of lock code are you asking for? Is it a phone lock or a network lock?
If it is a phone lock, You must do a master reset for your Nokia 7610. This could restore your phone with default factory settings.
If it is a network lock, You need to enter the unlock code. You can get the unlock code either from your network provider or from any trusted vendor online. For example you can get the unlock code from www.unlocking4u.com/nokia-7610-supernova/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Nokia 7610 SUPERNOVA,
1 - Switch on your Nokia 7610 SUPERNOVA without any sim card.
2 - Don't bother as to what is displayed on your Nokia 7610 SUPERNOVA.
3 - Compose #pw+CODE+1#.
4 - The Nokia 7610 SUPERNOVA would then display the message "SIM Restriction Off" and will be unlocked!
Sep 13, 2012 | Nokia 7610 Supernova Cell Phone
WHAT STEP TO FORMAT NOKIA 7610
Here are the tips to do follow my steps carefully:
1) Turn off your Nokia phone
2) Remove your SIM CARD and your MEMORY CARD
3) Hide your SIM CARD and your MEMORY CARD in a safe place!
4) Turn on your phone while pressing: Ke(3) + Green call button + *
5) Your Nokia is now formatting, please wait for a while...
6) When done, reinsert back your SIM CARD and yor MEMORY CARD in to your phone
7) There you go! your code is now set to (12345)
Dec 28, 2010 | Nokia 7610
How to format my nokia 7610...
Method : Three Finger Reset for Nokia Phone
1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number '3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Have a good day!
Dec 03, 2010 | Nokia 7610
I have nokia 7610 n my mobile is blocked...
Its SIM problem.tray to ask PUK to provider SIM you used.use an other SIM with a same provider were blocked to call the call center. Or may be you can use your friend ponsell with the same provider, don't worry its free of charge.
Apr 18, 2010 | Nokia 7610
Phone startup failed
if your phone is what i can see in the above as 7610 nokia and it failed to start, though your problem is not really clear, what you can do are these.
1. romove your battery.
2. remove your sim
3. remove memory card.
4. reinsert battery, try to switch on if it still fails to start, proceed to step 5. if it starts, then reinsert all your sim, battery and memory card. and switch on.
5. while it is switch off, press *, 3, call key, and power on at the same time, to make a hard reset, but be aware that all your settings will be lost once it proceed to hard formatting.
take care.
Feb 23, 2010 | Nokia 7610
PUK code
hello
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
your only option is to call your phone service provider. No it doesn't come with the phone and the phone never has its own puk code because the puk code is about the sim card.
if you put in another sim card the phone will work just fine, its the sim card 3 times pin code wrong puk code enabled pin blocked, call service provider to get it and entry instructions.
Let me know if you need anything else.
Thanks,
Ekse
Mar 09, 2009 | Nokia 7610
Problem to call and send messages
Reboot your Phone, Maybe cvell C ? - that sucks, always does that
Apr 11, 2008 | Nokia N95 Cellular Phone
SYSTEM ERROR
Your solution depends on if system remain always in error status or it become usual after error message. First you should do hard formatting by removing sim and mmc then pressing four keys i.e. *,3,green send key and power switch simenteniously. Phone will get formatted and problem will be solved. If it doesn't work then we can say that there must be system file error. It can be resolved only by special tools like JAF or UFS.
Jan 02, 2008 | Nokia 7610
Nokia 7610
There are detailed instructions on http://nds1.nokia.com/phones/files/guides/Nokia_7610_UG_en.pdf
Sep 18, 2007 | Nokia 7610
Message Box problem
1st formate u r mobile
Sep 06, 2007 | Nokia 7610
Nokia 7610 Logo
296 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
