Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon Pixma MP530 All-In-One
I had by error place the smaller ink ink into the bigger slot, it was struck initially but I manage to remove it by force and the error code U043 keep appearing. Is there any way to solve it?
    Problem Solver:
  • 5 Answers
I had contacted Canon to resolve my problem.
Through the technician I am informed that the printer has to be sent back for service as one of the 4 pins on print-head print has dropped off leaving only 3pins that is why the error code U043 simply occur which is why replacing another new ink cartridge does not resolve the issue.
I have understand from him that:-
  1. Most of the time when error code flash up, usually are due to the unique feature that Canon has build on the ink cartridges not properly done which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges. Of course this causes inconvenient to users, but if users are not using 3rd party ink cartridges, once detected is Canon's ink cartridge issue, do contact Canon, they will provide house call for 1 to 1 exchange for the ink cartridge.
  2. Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  3. If your problem is like mine, inputting the ink cartridge into the wrong slot, well I guess only have to contact Canon as the printer's components used seem to be highly sensitive, by input the wrong slot would have caused scatches on the pin, well it is better to have the ink cartridge remove by the expert than to DIY. (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
I hope the above information will help all the troubled Canon printer users as I notice from previous search on this website, there are other users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again, by replace a new ink cartridge will help as the partial used one would be faulty already, and do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge.
Posted on Mar 28, 2008
Conon ******
Posted on May 20, 2012
Canon error 6400
Open the ink replacement cartridge and unplug the printer when the printer head assembly moves to the center. Check the rollers and other parts for pieces of paper that may stop them from moving properly. Check the purge unit to make sure no foreign objects interfere with its movement. It should move easily along its rails without being forced. Also make sure the small ink pads in the purge unit are secure in their holders.If you removed any obstructions, the printer should start working. If the error persists, you may need to take the printer in for service.
Dec 12, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Error code U052. I know this has to do with the chip in the ink cartridge. I changed all cartridges and still the same code. I cannot use any function on this MP530 with this error code.
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Now insert cartridges and see if error goes away.
Do not forget to rate my answer.
Jul 06, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Printer will not accept ink cartridges - displays "check ink" even with brand new cartridges
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Jan 28, 2010 | Canon PIXMA® MP530 All-In-One Printer
Open a canon mp530
If you don't have an error code, when the printer is turned on and you lift the control panel up, the carriage will move to the center so that you can change your inks...
Jun 24, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error code 5C10
From Canon. Issue: ERROR LCD: Error Code 5C10
1. Press ON/OFF switch to reset the multifunction device 2. The MP530 may require repairI would remove the print head and inks,unplug it completely from thr eall for a half hour.Plug it back in and install everything.
Jun 17, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I forgot how to change ink cartridge on my printer CANON MP520
usually with the pixma range, if you lift the lid to expose the cartridges, the printer will automatically bring the print head along to the opening to allow you to exchange the cartridges, once it does, simply press down on the exposed cart, and remove it from the printer, the new one is then placed in the now vacant slot and gently lift up the edge until it clicks in to place. Close the lid and the printer will do the rest.
Oct 24, 2008 | Canon PIXMA® MP530 All-In-One Printer
How to remove the ink cartridge from the wrong slot for canon mp530
There is no solution to this problem unless you know how to take the printer apart to remove the cartridge. The printer has probably been damaged when trying to get the cartridge out anyway so my solution is buy a new printer.
Jul 26, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
halo dear
for mp530, you can use a plugins catridge ... as cahnge your chips original , after use that you can refill your catrigde as well
the price about $4-5
try this site for clear information
http://exchangerate.ws/inkjetprinter.php?printer=Canon+PIXMA+MP530&lazySID=LcuxpiHFCsshJVujrrruBaNoo1203340519
oke
thks
cropp
Feb 29, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP530 no cartridge
Hi Cathy,
First, take the ink cartridge out and wipe the ink head with a tissue. If that dont work try to re-install your printer drivers that should reset your printer back.I hope this helps you.
Jan 17, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
451 people viewed this question
old marine
old marine
