Question about LG Washing Machines
Code UA or UE keeps on comin up on my lg
Code UA or UE keeps on coming up on my lg wm16220fd - after the wash cycle -
    Genius:
  • 1,400 Answers
Hello
Hold down the pause and cancel buttons for 5 sec.
Or unplug unit for a min and plug back in to reset.
Posted on May 04, 2010
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
Getting a E1 code one the front panel and will not finish the cycle
There is not a reference for an E1 error code.
The listed LG error codes are:
IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
May 18, 2010 | LG WM2016C
What does UE mean in the window of my washer
UE = Unbalance Error. If you are doing a large item and cannot add, reduce, or adjust the load, try adjusting the spin speed to a low spin speed setting. If the load is still too wet, you can run just a pump and spin by turning on power and then selecting the spin speed, one setting higher than the last one which ran the full cycle through without resulting in the UE code,(without selecting a cycle) and push start.
Feb 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
Oct 28, 2009 | LG Washing Machines
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Washing Machines Logo
430 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
