I have a Philips 42pf77220a/37, I turn on and get 6 red flash and 3 fast- over and over. If i un plug and wait to reset 3rd time pic comes back on after flickering a few times stays on. Im told power supply lj 4400101b/ps-424-ph is part i need?????? or REV.7 will also work?? WHAT SAY YOU Hal
  • 6 more comments
  • halradtke May 04, 2010
    i
    just bought it 3 weeks ago
    I just bought this tv 2.5 weeks ago so give me the best guess
    no clicks, just when it turn off and on.
    it will run good when warm but cold start takes 3 try to warm up, plug un plug 3 times
    like it doesnt have enough power to start?
  • halradtke May 05, 2010
    yes used, its 4 years old- 06 tx
  • halradtke May 06, 2010
    Im sorry, Model is 42pf 7220A/37
    So no one has seen 6 red led flash steady and 3 fast?
  • halradtke May 07, 2010
    yes
    yes
  • 5,807 Answers
Hi
halradtke,
There are many possibilities, It could be, But If you have a spare
cord, have the Power cord replaced or checked first.Have it unplugged
for a while to drain the capacitors inside for voltages.
Troubleshooting these Plasma sets would be best if you have
equipment , tools , service manual and a technical know-how to handle
electronics servicing, or have someone to help you.
have a check on Y Sustain Board should you wish to troubleshoot.
Just be careful with the Ribbon Cables connecting the Y-Sus to
the Y -Drive Boards.
Regards,
palaboy
Posted on May 04, 2010
  • 2 more comments
  • Rommel Cana
    Rommel Cana May 06, 2010
    here are some of the reasons why i insist on having a service manual
    http://www.fixya.com/support/t4691717-re...
    the flashes will indicate what maybe the possible cause of the symptoms you are having.
    It can only be well diagnose with the aid of the Service Manual
    the service manual can be downloaded here:
    https://www.completeservicemanuals.com/P...
    only with a fee.
    I would rather not advise buying the power supply board , not unless we are sure it is really
    the one causing the failure.
    if after , having a visual on the Board , that you cant find any bad capacitor
    like one of these:
    then you may need to check for other voltages.
    Here are your guide for Voltages on the power supply
    As you read over the service manual you can find the true replacement on the board which you
    are looking.
    There are many replacements on line, but I cannot guarantee it will solve your problem,
    not unless verified and cross-checked on the service manual.
    Some have solved their problems by just replacing the two capacitors on the power board
    some includes the Y board , hope you understand what I mean.
  • Rommel Cana
    it uses the same service manual
  • Rommel Cana
    Rommel Cana May 07, 2010
    Additional info:
    These sets comes with a built in microcomputer inside.
    All are based on Voltages.
    If ever it detects a fault on startup it enters into protection mode.
    The voltages for your unit is specifically designed for that Model ( see the image above ).
    Should you decide to replace the power supply, I suggest measuring first what output voltages
    your TV have.
    Then , if ever you have the replacement , you need to compare the output voltages reading
    of your former power supply and the new one.Neglecting to comply with the specifications
    will just /might produce undesirable results. ( Vs and Va settings )
    While you are ordering , you may try to check the foil side of the board, there might be
    cracked solder joints on the two capacitors ( with uf and volts values )
    ( if there is no bulging ) and have it resoldered.
    6 blinks means a fault on buffers and Y board.
  • Rommel Cana
    you may also need to discharge the main capacitor with a 2K 5 W resistor , should you need to check
    the boards.
  • 15,935 Answers
This is a bad capacitor set on the power supply.
Take the power supply out - and have them replaced if they are bulging/leaking.
1) Turn TV on (TV clicks) and green light appears - wait TV will either start or
2) TV clicks then shuts down and goes to blinking red lights <error code> (3 - I assume in your case)
3) Pull plug on TV (back or at supply) wait for light to fade/go out on the TV
4) Plug in again (press on button if necessary) - wait for TV to start or if it clicks unplug immediately (don't wait for error code to flash) repeat from step (3)
My belief is (in the case of 6 blinking lights and bad capacitors) is the necessity to slowly build up the charge (capacity) within the defective capacitor(s) until they allow the 'protection' circuitry to proceed. It's rather ironic that (at least in this case) it's the so called 'protection' circuitry that's preventing the TV from starting.
Thanks!
Posted on May 06, 2010
    Genius:
  • 1,043 Answers
I was attempting to find some service information for you, however, I am unable to find the model number that you have provided us with. Phillips usual numbering scheme would have 42PF####A/37, so there would be only 4 numbers past the PF designation. Could you please double check your model number? There should be a plate on the back of the TV with your model and serial number on it, close to all of your connections. Hopefully I will be able to find some information. The system will advise me as soon as you send me a reply. Thank you for allowing us to assist you.
Posted on May 05, 2010
  • 4,889 Answers
It does not sound like a power supply issue to me. On most Philips plasma's I have seen power supply failure produces 7 blinks. However I would like to know whether you hear a clicking noise when the screen is flickering. Please provide this info so that we can continue with the diagnosis.
Sai.
  • 2 more comments
  • eagle338
    eagle338 May 05, 2010
    That actually does sound like a power supply issue. The possible source of the problem is faulty capacitors that are taking longer to charge than usual. A component level repair might be possible. Also if its only 2.5 weeks old then why do you want to fix it? You can use the warranty to get a replacement or did you buy it used?
    Sai.
  • eagle338
    Ok.. then. You should look for capacitors that are leaky or bulged at the top instead of being flat. It is the most frequent cause of the problem you have mentioned. Replacing them with those of exactly the same values should do the trick.
  • eagle338
    eagle338 May 06, 2010
    I told you where to look but you were not interested in my solution. If you change your mind let me know and I will see you through this.
  • eagle338
    eagle338 May 07, 2010
    Ok. If that yes was for me then do you have a multimeter which is capable of checking capacitance? If yes then begin by testing the 120V rated capacitors for blown ones on the power board. Its a 90% chance that you will find something. Try it out and let me know.
    Sai.
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Philips 42pf9431d/37 stopped coming on won't come on and red light on front flash s 7 times pause 7times over and over
Unplug the television from the back or at the recepticle. Wait 60 seconds or so and plug back in. This will reset the TV.
May 25, 2014 | Televison & Video
I have a 50" Philips
Most likely the power supply capacitors are going bad.
Opening the TV and replacing any swollen caps may solve your issue.
Thanks
Roety
Aug 16, 2011 | Philips Televison & Video
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
My Philips LCD model 52pfl7422d/37's red light blinks 6 times slow and then 3 times fast. Any idea what disaster this coded message refers to?
if no sound and no picture -- check the fuses and disconnect all cables -- wait one day and re connect - if you solution -- might need a new power supply board
Feb 24, 2009 | Philips 52PFL7422D/37 TV
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
Electro Med Services...
