Question about Carrier 38CKC036 Air Conditioner
Carrier gas pak ..
Only blower is working..will not shut off...no heat is generated...for awhile I could turn off power at fuse box and unit would provide heat for several cycles...but not now
  • Samuel Allen
    Samuel Allen May 11, 2010
    Request aditional information
I had the same problem and the result was an $82 limit switch just needed to be replaced.
Posted on Jan 06, 2009
Carrier products fall into a fail safe mode when any of the various overtemp sensors open or fail. check all of the micro switches that are around the burners and if any are open then that is your reason for the indoor fan to run nonstop. now you have to look at what caused the sensor to trip open. usually over heating. possibly a bad capacitor on the motor or the motor itself . or it could be excessive gas pressure creating to much flame and heat. test the gas pressure with a manometor. you can pick one up for about 100 bucks or call the gas company and see if they will come check it for free. then test the burners by observing flame pattern and flame rise off burners. then check the heat exchanger with a carbon monoxide detector . you can pick one up for about three hundred dollars . or try to get a gas guy that has one to check it. you may very well wind up calling a pro cause a simple mistake and you can easily kill some one or burn down the house. messing with gas aint the best way to save a buck. good luck.
Posted on Oct 15, 2008
  • 86 Answers
1. check indoor wiring.
2 check selector switch.
3 heater not working.check heater eliment also.
Posted on Mar 28, 2008
SOURCE:
Why won't the spa turn on?
The best way to detect where your problem may be is by testing each unit associated with your hot tub. Start by turning off the main power, now unplug all the accessories on your power pak
  • pumps
  • blowers
  • lights
  • ozonators
  • radio
something is tripping your power pak and this is the quickest way to find out. Turn the main power back on. Plug in each accessory pausing between, when the pak trips you know you have found your issue. It could be as easy as a fuse or a ceased pump.
Once you find out what needs to be repaired you may want to call out a hot tub service professional to repair the unit. Hot Tub Power Pak Repair
Jul 27, 2015 | Pool & Spa
My heating unit is coming on and just running not blowing heat at all. what could be wrong?
my first impression is that the filters are too dirty and they caused the high limit to trip. needs serviced.
Jan 31, 2015 | Carrier WEATHERMAKER 48TCEA 4.0 ton Gas...
Carrier electric furnace/air handler stopped running
Check fuses first! If yours is the model with a fuse box you will see a flap that pulls down to reveal a block of fuses, the blade fuse you described is part of it too! Are all fuses ok?
Nov 08, 2014 | Heating & Cooling
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
Runs for awhile shuts down and will restart but will run awhile and shut down
Check your oil, you have a low oil sensor on your unit and if the low oil sensor will shut the engine down,
Aug 28, 2011 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
I have a Carrier Gas Furnace Model # 395CAV024055ABJA, I works fine if you keep the temp low, like 68, so that it doesnt come on very often, but if you try turning it up and it needs to run for awhile, it...
It sounds like it is going into overheat mode. Check the overheat sensor, make sure the flue is clean, make sure any filters are clean, also check the gas passage inthe heat exchanger, if there is a blockage from soot the system will overheat
Feb 24, 2011 | Carrier Heating & Cooling
Carrier 58RAV "blower on after power up" error 12 problem
Hi Rick; Two things . You have a faulty control board. You have a high limit safety not reset or faulty...Is the gas valve in the on position and have You paid Your gas bill. I have encountered these problems before with my service calls...alpharome416
Jan 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
The heat will not work. No heat.
So you have power to the control unit and the blower motor. Did you check the blower motor resistor? That controls the blower on all speeds except for high speed. Did you check all the grounds? Don't rule out a faulty ground. Make sure the blower motor is properly grounded.
Sep 02, 2009 | 1991 Ford Escort
Carrier 38CKC036 Air Conditioner Logo
115 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
