Question about Sharp Heating & Cooling
Model AF S120 PX will run but doesn't product cool air. The unit is 3-years old and is cleaned each year.
  • 674 Answers
Make sure the outside unit is running. If it isn't make sure it has power going to it. If it has power and the fan and compressor are running then get the refrigerant charge checked. If the fan or compressor or both aren't running, make sure the thermostat is calling for air then see if the contactor is pulled in. If it is check your capacitor. Let me know what you find.
Posted on May 04, 2010
Idylis Model 416709, about 3 years old. Was working perfectly. Now starts cooling for about 5 minutes, then starts blowing warm air. Any idea what I can do?
Sounds like a problem with the drain or the outdoor unit. Clear the drain, make sure fan is running on outdoor unit.
May 28, 2017 | Heating & Cooling
How do I purge air from my Jeep's cooling system?
which engine?
after a there will be air.
on all cars. all engines and the solution (no pun) is the same.
overflow tank cleaned and filled with 50% AF to the mark.
fill it with cap off RAD, dead cold.
the run engine until coolant starts to expand and overfill the neck
cap it, off, and drive around the bock 1 to 3 times.
stop
let it cool
then off the cap see air there?, bingo, repeat above until no more air.
on cars with hoses higher that rad cap (rare cars, or very old jeeps 1988)
we had to do more magic, the shop manual reads like a horror that year. jacking bumper up high bla bla. but not this car.
Oct 18, 2014 | 2000 Jeep Grand Cherokee
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Cooling doesn't stay on
    The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
    Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
    We have a goodman air conditioning unit it just doesn't seem to get cool. It is only 3 years old. We changed the filter and reset the thermostat. What could be the problem. It sounds like the...
    I am assuming from your problem description that the unit is cooling some but not as good as normal. If that is the case then the system has lost some of its refrigerant charge.
    Recharging the system will correct the problem but only temporarily.
    The system has a refrigerant leak that must be found and corrected for a complete repair.
    Be sure to get a reputible( ask other people for a reference based on integrity and skill) heating and air contractor/technician. I would suggest staying away from big companies as their technicians are poorly trained.
    If they say you have a refrigerant leak , have them show you exactly where it is and have them squirt bubble solution on the leak so you can see it.
    If your system is only 3 years old then any major parts are under warranty. This does not cover labor.
    Hope this helps.
    Sep 06, 2011 | Goodman Heating & Cooling
    Had unit for 4 years do not use it awhole lot put
    Good job, on cleaning the air intake filter. Some folks overlook that. Since that helped some, I believe you need to clean a little further. Like the cooling coils and the cooling fins for the compressor. But, before attempting any cleaning turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet.
    You can clean the coils with warm water and liquid dish washing liquid,. Rinse and dry thoroughly. When dry, apply a light coating of WD40.
    The fins can be cleaned using an old toothbrush and a vacuum cleaner that has a hose and brush attachment or crevice tool.
    Completing this Annual Type Maintenance should provide significant results.
    Jun 21, 2011 | Haier ESA3125 Wall/Window Air Conditioner
    Runs well in evening, during heat of midday shorts out.
    Clean coils both inside and out. Then see what happens.
    Jul 07, 2010 | Sharp AF-R100DX Air Conditioner
    The unit is a 12000 BTU energy efficient model purchased from Lowes 3 years ago. It is not cooling. The fan runs fine but it just isn't cooling. The filter doesn't need cleaning. What could it be?...
    The compressor is probably not running.
    The Main reasons that this will happen
    1 - A bad run capacitor (silver or metal capacitor)
    It’s either shorted, grounded or open.
    If it’s shorted a lot of times it will bulge out, (sometimes slightly)
    2 - A bad start kit ( plastic capacitor and Relay connected to it )
    The capacitor is either shorted or open
    The relay either has an open coil between terminals #1 and #5
    Or the relay is stuck.
    Any time you change the capacitor or relay you should change
    the other, especially if they are over a year old.
    3 - A loose, burnt or disconnected wire
    4 - Wired wrong
    5 Compressor is open (windings burnt open)
    6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
    7 Some compressors have a black plastic overload under the compressor cap which could be bad.
    Jul 30, 2009 | Frigidaire 12,000 BTU Compact II Room Air...
    Heating & Cooling Logo
    46 people viewed this question
    Top Sharp Heating & Cooling Experts
    Oloyede Monsuru
    Tim Whalen
    Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
