Question about IBM ThinkPad T23 2647 Notebook
How to remove bios setup password - IBM ThinkPad T23 2647 Notebook
    Sergeant:
  • 279 Answers
1. Unplug AC cord
2. Take off PC Battery
3. Take off CMOS battery (located inside the mainboard), leave it for 5 minutes, re insert CMOS battery.
Posted on May 04, 2010
Lenovo T61 Power-on password. Hi, my Lap suddenly asks me a code that I unknow. It doesn't able access to any setup, even when I press F1 to open BIOS Setup Utility to remove. I removed Backup battery...
The BIOS password isconfigured from the BIOS setup and this password is stored on an 24RF08 EEPROM chip. There is no backdoor passwordavailable and IBM/Lenevo support says the motherboard needs to be replaced.Also removing the BIOS battery to discharge the BIOS and reset it to thedefault settings will not allow you to bypass this password. This also applies to thePower On Password and the Hard Disk Password.There is a way to crack thepassword but you need electronic skills, electronic components and severalprograms plus a working computer to carry out this task.For details on how to dothis check this WEB site.http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Feb 07, 2012 | IBM Computers & Internet
When I turn the laptop on I see the Toshiba screen for just a second and then it instantly goes to this lovely black screen that says password= How this got there I have know idea. Can anyone help?
Dear beanbean,
This "lovely black screen" is a BIOS password screen. This shows up because somebody has set a boot-up password in the BIOS Setup. If you're lucky, the BIOS Setup is still unprotected, and you can access it as follows:
When you turn it on, look for something that says "Press [button] to enter Setup" or "Press [button] to enter Setup Utilities." Press the corresponding button on your keyboard, and you should enter BIOS Setup.
Now two things can happen. Either you are permitted to access Setup, or you are prompted for the password.
If you can access Setup, navigate to the Security tab and clear all set passwords.If not... then you can either reset BIOS by unplugging the computer, taking off the back, and removing the CMOS Battery (unrecommended), or you can call Toshiba support and ask for the master password (Most manufacturers have a master password, which will allow you to access Setup and remove the boot-up password)
Hope this helps,Ericthecmh
Sep 13, 2011 | Toshiba Satellite A105 Notebook
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Starting with the computer fully off, turn it on by pressing and releasing the power button.
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
Black screen with a enter pass word
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password..
OR there are other places that will sell you a "Key" for a price.
OR you can provide "Proof of Ownership" to Toshiba, and they will sell you a "Code" to remove the Anti-Tamper, Anti-theft, protection.
Apr 07, 2010 | Toshiba Satellite A135-S2276 Notebook
Can't remember password
BIOS password remove alternatives:
1. Reset Password BIOS via Backdoor BIOS Password.
2. Reset Password BIOS via Software.
3. Reset Password BIOS via hardware.
4. Reset Password BIOS via default manufacturers.
OK, here is my guide to Remove Acer Bios password computer via Software. This has been done on testing machine Laptop Acer Aspire 3620/ Travel Mate 2420. Anyway, I'm not sure it will work on every Acer PC/Laptop so just consider to do at your own risk, I’m not responsible for any damages caused by this guide.
As we know most of Acer computer (Laptop & Desktop) allow us to setup BIOS in Microsoft Windows (9x/XP/Vista) environment. Great, this is the powerful that help us to remove the BIOS password cuz all we know if we enter Setup Utility at the boot time we have only three times of filling the password and if all wrong then the system will halt.
The program helps us to enter Acer BIOS setup in Microsoft Windows is “Acer eSettings Management” which comes with the CD when we buy Acer PC/Laptop. If you lost the CD then just come to Acer website to download the program.
Feb 02, 2010 | Acer Power 1000 PC Desktop
I FORGET MY WIPRO BIOS PASSWORD NOTE BOOK WIVNB7B1600, HELP MR?
I have a wipro wivnb7b1600 notebook & I don't know my bios setup password.
Can you help me? Hope your password send you to my mail
Thanks!!
Your Faithfuly moon
email: moon52619@gmail.com
Apr 01, 2009 | Computers & Internet
Bios password
You will need the BIOS password to enter the BIOS setup.
To do a hardware reset remove the CMOS batteries for 30 minutes. Once your BIOS password is removed, you will need to press the <F2> key during POST (Power On Self Test) to enter the Acer BIOS setup.
After you enter BIOS, go to the Boot tab and down to "Security" and make your changes there.
If you need help with the default password, please re-post your request.
Thanks and good luck.
Mar 19, 2009 | Aspire Acer 7520-5324 Laptop
I Forget the BIOS setup password
When you start your computer, tap F2 key to enter the BIOS setup. In the security menu is the area for removing/resetting BIOS password.
Feb 18, 2009 | HP Compaq nx8220 Notebook
What the easiest way to reset the bios setup
just remove the bios battery and place the same there your bios password will be resetted.
and also check this link there are many bios password changing techniques
http://www.tech-faq.com/reset-bios-password.shtml
Feb 01, 2009 | IBM ThinkPad R52 Notebook
IBM ThinkPad T23 2647 Notebook Logo
79 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
