Question about ASUS G71G-Q2 Notebook
My laptop is fairly new, I had been useing it just under 6 months when it suddenly turned off on me. I checked the power cord and looked at the led display and it said the unit still had power... I unplugged everything removed the battery plugged it back in and tried again. Still nothing, I can see no reason why its not working considering it worked just fine last night, however it refuses to turn on. Any ideas?
  • 74 Answers
Try to go into safe mode with networking and run a complete spyware and malware scan
Posted on May 04, 2010
Suddenly won't turn on no charge light indicator
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 25, 2012 | ASUS G71G-A2 PC Notebook
I have been using my Acer Aspire 4520 laptop for four years. Recently while working, it turned off abruptly, and when I tried to restart it, it didn't turn on. Upon pressing the power button to start...
Have you come up with a solution yet? Mine does the same exact thing nothing seems to be helping. I'm at a loss here and I feel helpless, and hopeless!!!
Sep 10, 2011 | Acer Aspire 4520 Notebook PC
I hav my ASUS Eee PC 1101HAB netbook, i was charging it while im using,after an hour or two, i noticed that it stops charging. i checked my charger and saw that the LED is off. i tried to unplugged it, and...
Hello.
Hello.
The most common reasons are the battery, power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
In any case, since your netbook is still under warranty, I strongly advise you to return it where you purchased, for a repair or replacement. A two-month old network should not have power problems.
Hope this helps.
Dec 26, 2010 | Computers & Internet
Install new HD, plug into wall, no lights come on.
Are you sure the HD was installed correctly? The pins not mating properly might be the cause of the problem.
Make sure the power supply is working. Look at the brick (the box on the cord), it may have a light (an LED).
Dec 14, 2009 | Compaq Presario M2000 Notebook
Battery not charging
1. plug the power cord into the laptop
2. remove the battery
3. try to power on the laptop
if the laptop led lights up and/or powers up without the battery it can be determined that you need a new battery
if the laptop led doesn't light up and/or power on. then you may have a charging port or power cord problem
Apr 18, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Aug 15, 2008 | Dell Latitude D600 Notebook
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Sony KP-51WS500 wil not turn on
did you notice any color flashing at all during the poping? As that model is fairly famous for the green CRT shorting out or the flyback arcing. Does the power LED light up at all or possibly blink? Let me know about the LED and I will try to help you diagnose what the problem may actually be. respond to this same post, so I can keep this problem seperate as I have so many responses with different problems that its hard to keep them straight unless we keep using the origional request each time.
Jun 19, 2008 | Televison & Video
LED Power light turns on, but nothing happens
If you've only had it 6 months then I would suggest you contact the manufacturer for a warranty replacement. Their warranty period is 1 year so see what they can do.
Mar 15, 2008 | Disney Pix Max Digital Camera
Mach 3 cyclone hoover vac
I have a MACH 3 Cyclone that is only a few months old that just suddenly stopped working and went totally dead like there was no power going to it.
I tested the power switch and noticed that there was no power running to the switch.
I then noticed that the switch sat on top of a very long adjustable handle so I figured I would check the pwer connection at the base of the handle.
1) I unscrewed the 2 screws closest to where the power cord goes into the vacuum.
2) Pulled the small blue cover partially out (it wouldn't come out all the way)
3) I found that there is a power cord (looked like a really small extension cord) that runs through the inside of the handle. Adjusting the height of the handle must have made it come uplugged at some point. I plugged this cord back in.
4) I reattached the small blue cover and screwed the 2 screws back in.
This fixed the problem.
I am willing to be that this is a common issue with this vacuum cleaner. Its a 5 minute very easy fix and strongly suggest checking this if your vaccuum suddenly goes completely dead without warning.
Dec 11, 2007 | Washing Machines
ASUS G71G-Q2 Notebook Logo
75 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
