Question about Jl Audio CVR12 Kicker 12" CompVR Series 2005 Car Subwoofer (800 Watts) Car Speaker
Can a kicker cvr be fixed if it is blown if so how
    Scholar:
  • 111 Answers
Speaker lesson here. For space and time, I'll not get into certain nomenclature. Working from top to bottom, you have the cone, rubber surround, basket, spider, voic coil former, voice coil, and the magnet. The binding posts are connected to the tensil leads which connect to the spider and the voice coil. As the woofer is positively + and negatively - charged, it creates a magnetic field which moves the woofer up and down. There is a small gap between the magnet and the voice coil and former that's called a magnetic gap. This gap is what helps the speaker to move up and down, and creates the Xmax. The Xmax of the woofer is the maximum linear excursion the woofer can travel without causing permanent damage. With a blown speaker, normally the voice coil and voice coil former have been pushed out of the correct magnetic gap, usually around the top of the magnet. That means that the only way to fix it is to take the woofer completely apart. My suggestion is to just go and spend the money. A blown speaker is a sign of abuse, and voids warranties from the majority of companies out there to include Kicker.
Posted on May 13, 2010
SOURCE: how to install..........
COMTE UNA VERGA GRANDISIMA WEY Y SE CONNECTAN SOLAS IJUUUUUSU CHINGADA MARDEEEEEEEEEE
Posted on Sep 16, 2008
SOURCE: wiring diagram
how to bridge soloberic 12" L7, 4 ohms
Posted on Mar 27, 2008
bumpinjls
  • 13 Answers
SOURCE: 10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Posted on Dec 25, 2007
SOURCE: wiring
1st--on 1 sub put a wire connecting one red with white dot to the blk with white dot
2nd--do the same thing to the other sub !!do not wire a red/white to an all black
3rd--wire the full blk negetives to the amp, then same thing to the positive
Posted on Jun 22, 2009
  • 52 Answers
SOURCE: i have 2 kicker L5 subs and they are blown the
Yes you replace both voice coils. Get parts from another speaker but has to be equle in quality.
Posted on Apr 20, 2010
Can I wire a 2ohm Kicker CVR with a 4ohm Kicker CVR to a monoblock amp 1 channel
yes. google, impedance calculator and it will help you out on how to wire it
Apr 12, 2015 | Kicker Car Audio & Video
How do i wire a single 12" kicker cvr dual 2 ohm
Simple power fom amo to power on sub. Ground on amp to ground on sub
Feb 28, 2013 | Car Audio & Video
How do you take the cvr kicker apart
are you sure that you are capable of replacing the rubber ring if you don't even know how to take the speaker apart? I am Not sure that that's a challenge you want to accept.
Mar 11, 2012 | Kicker Comp CVR 12 x 12 Car Subwoofer
I have 2 12 in kicker cvr tryna drop to lower ohm
http://www.colomar.com/Shavano/dvc_spkr_wiring.html
Use the above site for several wiring schematics on dual voice coil speaker hookups. It will show how to wire for different impedance.
Also, I think the CVR 12's come in 2 ohm and 4 ohm impedance. See if you can check yours to determine which you have....
Jun 28, 2009 | Kicker CVR12 Car Subwoofer
How do you wire 4 kicker cvr dual voice coil 4ohms to a 1500.1 kicker mono block 1 channel amp, they sound distorted when i turn them up, how should i wire them?
Hello antjobe,
According to Kicker the 1500.1 is only stable to 2ohms. So you will want your 4 CVR's to present a 2ohm or higher impedance to the amp.
The best configuration would be to wire the voice coils in series (each sub 8ohms) and then parallel all of the subs to the amp (2ohms). Here's a link to the diagram.
Hope this helps.
Jun 08, 2009 | Kicker CVR12 Car Subwoofer
2 10 kickers not playing. . .
Hello zqueliz,
It's possible that the sub is blown, but it may be something else. You did not specify how the subs are wired to the amp, how many channels on the amp, or whether or not the CVR's are in separate enclosures. These specifics will affect how you isolate the problem.
1) Check all of the wiring: RCA's from head unit to amp, speaker wiring from amp to sub. Make sure there are no breaks in the insulation and that the wire does not come in contact with another wire or metal parts on the vehicle.
2) Remove the nonworking sub from the enclosure and check the wiring from sub to terminal inside. While you have the sub out, check the "braided" wires going from the sub terminals to the cone.
3) Reverse the wiring from the amp to the subs to see if the problem moves to the right sub. That will tell you the problem is not in the sub.
4) If the left sub still fails with the amp channels flipped, you find no wiring defects, and you can't see any physical damage, test the sub voice coil with a multimeter. Set the meter to read "ohms" on the lowest scale. The actual reading should be a little less than the rated impedance. If the subs are 4 ohm, the meter should read about 2-3 ohms. If the meter reads "0" (pegs) or if it reads "infinity" (no reading at all), the sub voice coil is bad.
Hope this helps.
Apr 29, 2009 | Kicker CVR12 Car Subwoofer
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
10 inch cvr kickers
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
Amp cuts out at certain volume
is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
May 17, 2007 | Kicker 04KX350.2 Car Audio Amplifier
Car Audio & Video Logo
646 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
