Question about Canon PowerShot SD1000 Digital Camera
Display problem Hello, I've had my SD1000 for less than 3 months. Sometimes the display goes black, I can still access the menu options and if I slide the button to review images they will display on the LCD panel. But even if I've just powered it on, the LCD is black, if I take a picture anyway, the picture is also black. Sometimes if I turn on the camera and turn it off again a few times it starts displaying correctly again. Is there a hardware problem with my camera or is this something I should be able to fix?
  • 5 more comments
  • Anonymous Apr 13, 2008
    We only purchased ours a couple weeks ago-only took 7 pictures so far at home and now we are getting a black screen as well. Definately no drops or damage to it. I can only review photos if I put it in slideshow mode and can't take any new photos.
  • Sleumas Apr 24, 2008
    I've had a Canon SD 1000 for quite sometime now...and it always worked well as I've taken thousands of pictures with it. Recently...my LCD stays black as well...but after awhile...it comes back up and is fine.
    Any thoughts?
  • Anonymous May 06, 2008
    I am a tech coordinator for a school that has recently purchased 4 of these cameras and 3 of the 4 are experiencing this exact problem. We have only been using them a few months! Nothing that I have tried has helped.
  • Deanasue May 13, 2008
    My three month old SD1000's LCD turned black while taking pictures. I can review pics from memory card, but cannot take new pics. They are black. Menu icons appear on the black screen. Any suggestions???
  • Livsey357 Jun 25, 2008
    yes i had my camera 6 months it has gone three times ti the shop because the screen is dark. The camera takes great pictures and video. they say the shutter closes up and it affects the sensor.
  • DreLV Jun 26, 2008
    I've had my SD1000 about 11 months now. The first camera had the problem with the lens not retracting and Canon repaired the problem. About 3 months after receiving the repaired SD1000 I am experiencing the same problem others have listed with the LCD screen blacked out while taking pictures. However, when I view pictures taken they show up fine.
  • chrisgarcia0 Jul 11, 2008
    I had the same problem. There are three different ways I've been able to get the display back to normal: 1) charge the battery, 2) press the display button on the lower left, 3) turn the camara off and slap it a few times on the back (as suggested). All three of these techniques have worked at various times.
I had the same problem with my SD1000 and was so frustrated with reading all of the troubleshooting "solutions".... After a couple of days researching, I finally stumbled upon a site that actually suggested turning the unit off and "slapping" it a couple of times (on the front) and that would work. Well, I though "what the hell" and actually tried it. OMG! it actually worked!!! I'm thinking that the shutter inside just got stuck and needed a little "slap" to loosen it up. Hope this finds you all well and works for you before you go our and spend a **** load on getting you camera fixed. See ya!
Posted on Jul 09, 2008
There is only a picture in the middle of the screen, and about 3-4 inches of black all the way around it. I went into the menu, but there is nothing there even remotely close to making it full screen. Any...
Main power supply regulator fault. The output voltage that come out from it is less than normal. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
Oct 19, 2013 | Sansui Televison & Video
The gas needle mostly goes up to a quarter or little less than a half tank when you fill up but not right away, sometimes it's about after you've ride 3-10 miles. The gauge will drop to the low level
therecould be a few things wromg simple fix, first check the float sounds like it has a hole in it take bolts out of bottom of tank an slide fuel pump an sending unit out there will be a arm that moves up an down on the end of thqt arm will be the float you can dip it in water to see if it floats or sinks replace if it sinks
Jul 28, 2013 | Motorcycles
How do I turn off the flash on my Cannon pouershopt SD1000?
Hello and Welcome to FixYa!
To turn off the flash follow the given steps:-
  • Turn on your Canon PowerShot SD1000 Digital Camera
  • Press the Flash Right Arrow button on the four-way control on the back of your camera to display flash options on the camera's LCD screen
  • Now push the Left Arrow or Right Arrow button to select the flash "OFF" icon. It's the third icon that display the flash symbol crossed out by a backslash symbol inside the circle.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
Black and white tv
Hello
Your RCA, system setup has changed I thinks.To change this you have to go to the Menu option surf for system settings, and change the system reception to "AUTO".
Setup
The Setup menu allows you to access the GUIDE Plus+ system setup information. To access the
Setup option:
1. If the GUIDE Plus+ system isn't on your screen, press GUIDE on your remote control.
2. Press MENU to select the Menu Bar.
3. Use the right arrow to highlight the Setup menu selection.
4. Use the up and down arrows to select Change system settings, Review options, or
View demo.
Change system settings Confirms the settings you completed in the GUIDE Plus+
system setup are correct.
Review options Displays the GUIDE Plus+ system auto display options.
On Automatically displays the GUIDE Plus+ system when you press the ON•OFF
button on the remote control.
Off Disables the GUIDE Plus+ system from being displayed when you press the
ON•OFF button on the remote control.
View demo Runs the GUIDE Plus+ system demonstration
Note: If you have not completed your GUIDE Plus+ system setup, these options will not be available. A
screen will prompt you to complete your setup.
Getting In & Out of the GUIDE Plus+ System
To enter the GUIDE Plus+ system:
• Press GUIDE on the remote.
• Press and hold MENU for 2 seconds on the front panel.
To exit the GUIDE Plus+ system:
• Highlight a program and press OK to exit the GUIDE Plus+ system and tune
to the channel.
• Press GUIDE to exit the GUIDE Plus+ system and tune to the channel
displayed in the video window.
• Press CLEAR to exit the GUIDE Plus+ system and return to the original
channel
OK.
Dec 04, 2010 | RCA 32V420T 32" TV
My camera will no longer show the image on the screen when I am taking a picture with my Canon PowerShot SD1000 digital camera. Can this be fixed or is it time for a new camera?
most likely you have turned the dispaly off. find the display key and turn the screen back on.
another option is to go into the menu, then go to display and set it there.
Jul 18, 2010 | Canon PowerShot SD1000 Digital Camera
My camera can play back pics and the zoom moves when I turn it on, but the camera LCD display remains black when I try to take a picture
Look in your menu to check you havnt turned the LCD Screen off as a battery saving option.
If not Take it to be repaired
Oct 06, 2009 | Canon PowerShot SD1000 Digital Camera
I have a cannon sd1000 , bought 1 month back. suddenly its stopped capturing pictures. i.e while in shot mode the display is black and not showing and capturing the image.but able to access al the menus....
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 17, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
Black screen, not capturing photos
have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Jul 22, 2008 | Canon PowerShot SD1000 Digital Camera
Zoom changes when camera turns on and camera is blocked
the only option really for it is service. you do have a 1 year warranty so long as you have a receipt / warranty card. you could just play with the zoom lever a little to see if it frees up
May 21, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
