Question about Whirlpool AWM8143 Front Load Washer
Program will not start, door light flashing
I have a whirlpool awm 8143/3 washing machine. When I go to start the wash it makes a few noises like its about to start but then it stops and the door open light begins to flash. The door will not open until the machine has been switched off and left for a few minutes. I was thinking perhaps a problem with the sensor switch for the door or sum sort of program error. Anyone have any ideas? Or anyone had a similar problem?
  • cwilson36 Jul 28, 2010
    Hey, I posted this ages ago but it turned out it was just the brushes on the motor. Twenty quid for a new set of brushes and very easy to fix. Just tip the washing machine over on its side and you'l see the motor underneath and you should be able to replace the brushes from there.
Has anyone had any joy with this? I have exactly the same problem.
Thanks
Posted on Jul 27, 2010
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
Whirlpool AWM 6100/s Front load washer
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
Nov 01, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 8103/1
What is the model number of your unit?
Nov 19, 2012 | Washing Machines
Whirlpool AWM 8143 - Starts a cycle and then starts flashing open door light and won't go further. Door is shut properly. Tried turning it off at the power and back on to no avail.
This is either a problem with the door lock itself or most probably a motor failiure as the door open light also indicates some kind of motor problem. If your appliance is 4/5 years and above then you will most likely need to change the set of carbon brushes on the motor and this will solve your problem
Jan 18, 2011 | Whirlpool AWM8143 Front Load Washer
Describe your AWM 8143 motor noise
once your motor ahs gone mate that's it, you need a new one!!
May 25, 2010 | Whirlpool AWM8143 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Washing Machines
AWM 8143 front loader- rubber door needs to be replaced
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
Sep 07, 2009 | Whirlpool AWM8143 Front Load Washer
Washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
600 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
