Question about Ricoh Aficio 250 Copier
Ricoh 250 doesn't copy/print
Had written previously regarding the wrench light coming on and copier not printing. I did check the code and it is sc320 so it probably is the motor failure. Someone came out and looked at it( didn't charge me anything) and they said something about the scanner motor? not working so maybe this is one and the same. he said it was a major fix $$$$ and probaly not worth fixing because the machine is ten years old. The copier has been running fine no issues whatsoever. So if a part was available for $200.00-$300.00 I would probably try and do that Is it something that can be ordered , how would I find out what order number and where to order?? can this be a do it yourself project if I get the part?? my husband is extremely handy with mechanical stuff. But hate to throw away money if it really isn't worth fixing... Thanks Not sure I'm really asking a question just trying to get some guidance on how to proceed and not spend a fortune
  • 1,110 Answers
Http://www.precisionroller.com/find/g0201942.htm
You might be able to find them cheaper online. This will give you the part number. I can't say wether to fix it or not. It is a lot of money to put into a machine of that age. If you had access to good used machines I would say that would be better. Unless your in Kansas this is the best I can do for you.
Good Luck and Thank You for using Fixya.
Posted on May 04, 2010
Testimonial: "apprecite the honesty and info"
I have code SC320 of my copier NASHUA D425
SC320: Polygon motor error
-Definition- [B]
The polygon motor does not reach its operating speed within 10 seconds
after the polygon motor on signal, or the lock signal is not detected for
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
When I try to copy it goes through the process but then the wrench lights up and it actually doesn't print anything. the paper goes through but nothing is on it. It says to try turning off the machine and...
Whenever you get the wrench light there should be an SCxxx (x=3 numbers) code in the display. The problem you are describing tho sounds exactly like a laser motor failure. If this is the case you should see either an SC320, 321 or 322 code.
If so you are looking at between $200 to $400 to fix the machine depending on your local service options.
If this is not the code you are getting, just reply with the code so we can assist you further.
Apr 30, 2010 | Ricoh Aficio 250 Copier
I have a Ricoh Aficio 2027 copier/scanner/printer. Fuser problem?
yes i think your right a slight flat when you turn the roller is a problem. check gears and hot roller and rubber roller bearings. hope this help your problem.
Jan 22, 2010 | Office Equipment & Supplies
Our printer is stuck in copy mode and is printing
Blank pages = high voltage malfunction.Check the transfer/separator corona wire and grid,and the charge corona.
Oct 20, 2009 | Ricoh Aficio 250 Copier
Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Apr 10, 2009 | Ricoh Aficio 1013F Copier
Functional Problem SC321-00
What is the actual code. Your heading says '321', then you list "320"?
"320" is the polygon (laser motor) that is defective. "321" is more likely the BICU board.
Could simply require the LD pitch adjustment be performed, depending on what else you have done. Do both the 400dpi, and 600 dpi. initial setting
SP 2109-3 (400 DPI)
SP 2109-4 (600 DPI)
Mar 30, 2009 | Ricoh Aficio 450 Copier
Got problem with aficio250
Another thing that can happen to cause a jam when you are printing on there is to make sure that the paper size if correct and matches the trays you are printing to. That condition will happen if the printer tries to print a legal size page and you only have letter paper installed in the trays.
Check your settings in the printer control panel to make sure that the trays match and are correct.
Make sure that the green paper setting knobs match the correct tray size as well.
Jun 19, 2008 | Ricoh Aficio 250 Copier
Error Message SC320
We are buying a new machine! The price of the motor and labor is more than the machine is worth.
Feb 06, 2008 | Ricoh Aficio 180 Laser Printer
Code SC320
i'd exprience the same problem once. what i did was to change polygon size laser. its working perfectly now
Oct 31, 2007 | Office Equipment & Supplies
Ricoh Aficio 250 Copier Logo
113 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
