Question about Sprint Palm Centro Smartphone
My palm centro will not make or receive calls when i try to call it just says dialing then goes back to my screen saver please help
I'm having the same problem with my phone. What is the solution?
Posted on Jul 26, 2010
My screen is frozen
Hello tara_martell,
Have you tried doing a soft reset? All your information is retained when performing a soft reset. These soft reset instructions are from the Centro Tips, Hints and Shortcuts manual:
1: Press Power/End (Red Button) to turn off the screen
2: Slide the battery door downward (on back of the Centro) to remove it from the Centro
3: Remove the battery from the battery compartment
4: Align the metal contacts on the battery with the contacts inside the battery compartment, insert the battery, and then press it into place
5: Slide the battery door onto the back of the Centro until it slides into place
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 07, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Hi my palm centro keeps over syncing over and over again. i would like to know how to fix it please.
Hello elmorenocali,
The hotsync information in the Centro User Guide is very thorough and is mainly in chapters 2, 10 and 12. I hope the user guide helps with the hotsync problem. Here is a download link for the Palm Centro User Guide:
http://www.palm.com/us/support/handbooks/centro/centrorow_ug.pdf
Have a great day,
martyshaw152
May 08, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
Palm Centro - continous Syncing problem, now phone is dead
This happened to my palm centro and i fixed it myself. :) Maybe it will work for you. What i did was take out the battery and so the phone is completely off.. then take a tooth brush with rubbing alchohol on it and scrubbed the bottom part of it that the hotsync cord goes into.. I thought this may just mess up my phone more but i plugged it back into the power cord, turned it on and it worked just fine!! Seriously, try this out. It brought me so much relief!! And chances are you either got some **** stuck up inside there, or you got the botton part wet. Hope i helped!!
Aug 24, 2009 | Palm Treo 500 Centro
Hi, my palm centro has no sound. i.e, no speakerphone, no dial tone, no audio on videos but the alarm works that's it.
Hello rossgreni340,
First, make sure the ringer switch is set to 'ON'. It's the little button on top of the Centro. It's turned on when it's pushed to the left. If that doesn't help then check the Sounds settings. The Palm Centro sounds settings can be accessed and changed from the 'System' screen like this:
•Press the 'Home' button on the Centro.
•Tap the 'System' category (top of sscreen).
•Tap 'Sounds' to change the sound settings as you desire.
I hope this helps to resolve the sound problem.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw152
Jul 29, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm centro wont boot
Do a reset. You will lose all items on you device.
Take battery out. Put it in and hold the power button on till you see the palm logo the second time. Release when you see the 2nd logo. It will prompt you for pressing up to delete and reset. Press Up. It will take some time to reset and reformat but please wait.
After that your phone should come to the setup screen. I would hotsync after you setup to get your contacts  back.
Apr 25, 2009 | Palm Treo 500 Centro
Palm treo 680 receives call but can't make calls
Same problem, but mine began, when I changed between one Sim (telcel) to other SIM (Movistar).  Whith the second my phone works fine, but with the first carrier, all sims failed to make phone calls
Apr 02, 2009 | Palm Treo 680 Smartphone
Palm treo centro.
I had a frustrating problem, maybe the same.. No sound in or out of the phone, no "Speakerphone" or headset icons showing up on the "dialing" screen. after much frustration, hard and soft resets, etc. it turned out that an annoying and unwanted "voice dial" program had turned itself on and was screwing things up. I had to set it to "Never" use voice dial, now all is back to normal.
Oct 16, 2008 | Palm Treo 500 Centro
Centro GSM unresponsive at times
My Centro doesn't respond ("freeze") on incoming calls up to 10 times a day. The "answer" button (on the screen) and green "send" button (next to "phone") block and it is impossible to accept the incoming calls. It is necessary to perform a soft reset to solve the problem temporary. Even after hard reset the situation is the same. This is very frustrating for a new device. Sometimes, frequent callibration of the screen from the "Preferences" menue delays the freezing effect. AFAIK the problem is software-related, considering the recovery after reset. Is there any update on the palm support page / forums, related to the problem? I couldn't find any. From time to time, there is onother problem I experienced - from the contact menu it is difficult to dial the selected number. Sometimes it is necessary to press “dial” several times resulting in significant delay.
Mar 19, 2008 | Palm Treo 500 Centro
Treo 600 dropped calls
Try hard reset your phone
Dec 15, 2007 | Palm Treo 600 Handheld
Sprint Palm Centro Smartphone Logo
96 people viewed this question
Top Sprint Computers & Internet Experts
Computer Repairing
Computer Repairing
matt
matt
Are you a Sprint Computer and Internet Expert? Answer questions, earn points and help others
