Question about Sony PlayStation 2 (PS2) Console
I put the disk in and it will not spin
I push down on it and still noting
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
It sounds like your motor has burnt out or there could be a problem with the gear box. You can buy the replacement parts on ebay. If you cant fix it yourself you will need to buy a new system or have a professional do it.
Posted on Mar 30, 2008
My ps3 wont load the games
a piece inside the psp when the back is closed it pushes a clip down and starts the disk spinning
this clip in my old psp snapped off it may be replacable i think
Dec 07, 2013 | Video Game Consoles & Games
All of a sudden my disk and dvd movies will no longer pop up when i put then in the disk holder and push them in nothing happens i can hear the disk spinning for a few seconds and then it stops but nothing...
Insert a disk. Wait for the disk-spinning to stop.
Open "My Computer".
Double-click the icon for the CD/DVD drive, to see if Windows can read anything from the disk.
Jun 25, 2011 | Sony VAIO VGN-FE880E/H Notebook
1991 harley ulra classic has stock heads but adjustable pushrods with no colors. how do i adjust before firing motor
Hello
I hope this helps out.
the 2 long push rods are the exhaust and the 2 short ones are the intake.
jack up the bike so the rear tire is off the ground.
put in 5th gear so you can turn over the motor by turning the back tire.
it takes 2 people, one to turn the tire and the other to be looking at the lifter to make sure it is at its lowest point.
you should have all push rods in but very loose.
start with the rear exhaust and then rear intake then front intake then front exhaust.
turn the motor over with back tire, looking at the lifter, watch to see it get to its lowest point.
when it is at its lowest point, stop turning the tire.
now tighten up the push rod so you can spin it but no up and down movement.
now tighten to push rod specs(factory or aftermarket have # of turns or flats to turn)
yours should be 3 turns, but check your manual specs or call dealer and ask how many turns for that year just to make sure.
after 3 turns the push rod will be tight.You have to wait about 15-20 minutes for the lifter to bleed down. try to spin the push rod after 20 minutes. if its hard to spin, wait 20 minutes more, if its hard to spin then you may have over tightened the push rod.
if the push rod spins freely but no up and down movement, then the lifter has bled down and your ready to move to the next push rod.
repeat this process with each push rod.
once done, make sure the spark plugs are out and turn the motor over a few times, as the motor turns over, have your buddy stop when you see a lifter at its lowest point and spin the push rod.
it should spin free with no up and down movement. check them all.
thats it.
just remember to make sure the number of turns for the type of push rods you have.
call the manufacturer who makes your push rods, or call the dealer if they are harley davidsion.
Note: there is basically zero lash once the bike is running, because the oil takes up the clearance.
May 21, 2011 | 2004 Harley Davidson FLHTC - FLHTCI...
My garbage disposal jammed, (Badger. 5) I noticed this when I turned on the until and just heard a hum but nothing spinning. I shut off the unit and got out my allen wrench and inserted in the bottom and...
Just put a wooden broom stick into garbage disposal.
Wedge the broomstick against the cutter disk.
And push or pull broom stick against sink opening so it frees the cutter disk.
Oct 31, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
After extended power outage my laptop will not
Try holding down on the power button until the leds stay on ... then release it. Don't just tap or push the power button once.
Feb 06, 2010 | Microsoft Windows XP Professional With...
He dont recognize the disk
Put a disc in with the label facing up and note the orientation (ie rotation) then when the disc ejects, see if it's in the same orientation (rotation). If so, the motor is not spinning the disc and it would need to be serviced.
-=/ MLF /=-
Oct 20, 2009 | Lite On Televison & Video
Does not recognize any cds
Insert a CD that has writing on the top, noting which way the lettering is facing. Close the drawer. Wait a few seconds. Open the drawer.
If the lettering still is facing the same way, the disk did not "spin".
So, the motor that spins the disk is dead. Replace the CD/DVD unit.
If the disk does spin, then the laser inside the unit has failed. Replace the CD/DVD unit.
Sep 10, 2009 | Computers & Internet
Cd does not spin
the motor will need to be replaced
Apr 15, 2009 | Fisher SLIM-1500 CD Shelf System
My blueray cd is not reading
when putting disk in check by listening if you can hear the disk spinning at high speeds or a clickin noise, this means the laser is having trouble reading disk,try cleaning with a cd laser cleaner you can get these from comet argos pc world etc,if this does not work the laser may have burned out,one of the main faults with playstation and xbox is the fans that cool down the system also draw in dust through the vents wich inturn soil the laser lens hope this helps andy
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
Won't spin
Hi, is it a slimline one cos sometimes the switch that tells the console that the doors shut breaks. U could try pushing it down gently too see if it activates but i cant be responsible for breakages or possible blindness if you look into the laser. LOL
Mar 22, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
15 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
