Samsung LCD Vertical Stripe
I have a Samsung LNR329DX/XAA LCD TV. Several Months ago a greenish / blue vertical stripe about pinky width appeared just to the right of center on the screen. The TV is out of warranty. I've tried switching out cables, etc. and the stripe stay there. Anything to try prior to replacing?
  • 2 more comments
  • mtrump May 04, 2010
    How do I access the Tcon board? Do I take the entire back panel off of the tv or something else?
    There is a 4x6" silver plate with four screws and a flat cable going into the bottom of the plate. Do I replace this cable or just unplug it and reset it?
    Didn't work. Would replacing LCD panel definately fix and how would I obtain a part number and could I replace it myself?
    PS - should I try to do some sort of reset since replugging the t-con?
  • 10,594 Answers
Apparently its problem of LCD Panel that need to be replaced.
However, there is T-Con board located at top center of rear or lcd panel, remove its metal cover and reinsert flexible ribbon wires coming from lcd panel, some times it helps to fix stripe issue.
Below is an image of rear of lcd panel that shows T-Con board location on lcd panel.
Hope this info will help you.
Thanks.
Posted on May 04, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics May 04, 2010
    Yes, unplug tv from wall socket, take off back cover and look on top center area at rear of tv as marked in above exploded view/ image.
    And if you feel uncomfortable working in tv, local tv repairman will help you.
    Let me explain again, some times refreshing T-Con board connection solve the issue but not always and mostly lcd panel is culprit.
    and reset it?
    Do not attempt to replace cable, just unplug it from t-con board connector and replug back to refresh connections of cable and connector.
    That cable is directly connected with lcd panel. Handle it carefully.
    LCD Panel would be available with nearest Samsung service center but would cost you approx 70% of new tv price.
    Shop Jimmy could also be source of required lcd panel on less price, if they have it in stock. Please call for lcd panel query as numbers are mentioned at bottom of that web page.
    Reset wont work because its hardware problem of lcd panel.
    It is not some sort of software bug or settings problem that can be fixed by resetting.
What causes a Blue Vertical Stripe on left side
Can be the t con board or the lcd panel. its only possible to finalise by replacing the t con board. Before going for a new t con board try to check the connections from t con to lcd panel. if its possible remove and reconnect it. sometime bad contact can cause such problems. Also added a link which would be help full for you.
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 09, 2015 | JVC Emerald EM37T 37" 720p LED-LCD TV -...
5 inch wide blue vertical stripe on lcd
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Dec 06, 2012 | Toshiba 46LX177 46 in. LCD HDTV
Hi, I have a Vizio P42. Worked fine for 5 years. Today is has a vertical blue stripe 1.25" wide, 4" from left side of screen. Blue stripe remains even if all inpust cables are removed. Problem is...
it's burning out. that's a sign of tv failing. there is no repair for that if you used it for 5 years, i doubt you would have warranty for that by now, best option is to replace it.
Oct 17, 2009 | Televison & Video
I have a vertical stripe on the left side of the screen that comes and goes. It appeared after my wife and I watched a vhs video on our Samsung 42' lcd hd tv.
first of all hello!
look i need to know a little bit more of your problem so i can help you!
let's see first of all how often is the problem happening ? after a wile the lines go away or they are always there? please let me know because i think i now what is the problem i just want to make sure!
yeah have a good day!
Sep 22, 2009 | Samsung HL-S5087W DLP TV
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Big vertical tinted stripe on screen
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Dec 12, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Open Questions:
Televison & Video Logo
382 people viewed this question
Top Televison & Video Experts
Electro Med Services...
