Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Release clutch/ brake pedal engine stops / as well engage clutch lever for mover / engine stops. Thank you for taking my question . engine runs well no problem starting engine stops when place mower in gear or engage mower blades engines stops.
  • 1,498 Answers
Hi Carl,
Just had this happen to me. The mower had sat all winter. During that time a couple bearings froze up.
It took a pipe wrench to free them up.
I worked in some oil and that solved it.
You need to check each pulley and bearing to see if you can spin it. If you can't, oil it first, then try to **** it free.
Once it lets go, a little more oil and you are all set.
Best regards
Mike
Posted on May 04, 2010
How to set and release the brake
You would depress the clutch/brake pedal all the way down and then pull or activate the brake engage lever or linkage. To release it normally all you have to do is fully depress the clutch/brake pedal and the linkage or lever will automatically disengage.
Jan 20, 2016 | Garden
When i depreesed the clutch my truck is moving
If it has a hydraulic clutch it may low on fluid, check both brake and clutch fluid levels.
Sep 29, 2014 | Cars & Trucks
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
1998 ford contour 2.5 ltr manual,stuck in second and have to hold the clutch in to move it.how do i solve this issue?
SECTION 308-00: Manual Transmission/Transaxle and Clutch - General Information 1998 Contour/Mystique Workshop Manual DESCRIPTION AND OPERATION Manual Transaxle and Clutch Manual Transaxle and Clutch - General Information This section covers general procedures for diagnosis and testing the clutch system. For additional information, refer to Section 308-01 . For specified clutch system service procedures. For additional information, refer to Section 308-02 . For a complete description of the manual transaxle. For additional information, refer to Section 308-03 .
The clutch system includes:
  • Flywheel.
  • Clutch disc.
  • Clutch pressure plate.
  • Clutch master cylinder.
  • Clutch slave cylinder.
  • Clutch release fork.
  • Clutch release hub and bearing.
The clutch master cylinder transmits fluid pressure to the slave cylinder, which in turn moves the clutch release fork and the clutch release hub and bearing.
The clutch master cylinder uses brake fluid and shares a common reservoir with the brake master cylinder
The clutch is a single plate, dry-friction disc with a diaphragm-style spring clutch pressure plate. The clutch disc has a hub which is splined to the input shaft. The clutch disc has friction material where it contacts the flywheel and the clutch pressure plate. Torsion springs on the clutch disc help absorb the engine torque pulses. The clutch pressure plate applies pressure to the clutch disc, holding it tightly against the surface of the flywheel.
In the engaged position, the diaphragm spring holds the clutch pressure plate against the clutch disc, so that engine torque is transmitted to the input shaft. When the clutch pedal is depressed, the clutch release hub and bearing pushes the diaphragm spring center toward the flywheel. The diaphragm spring pivots at the fulcrum, relieving the load on the clutch pressure plate. Steel spring straps riveted to the clutch pressure plate cover pull the clutch pressure plate from the clutch disc, disengaging the engine torque from the transaxle and enabling the gears to be changed.
Inspection and Verification - MTX-75
The following checks should be carried out before repairing or replacing the transaxle:
Poor gear shifting
  1. Check the operation of the clutch: Lay a block of wood approx. 25 mm thick under the clutch pedal and depress the clutch pedal as far as the stop. If 1st or 2nd gear can be selected with no problem with the engine running and the parking brake applied, the clutch is OK. If the gear cannot be selected, repair the clutch.
  1. Check the selector mechanism:
    • The free play in the gearshift lever must be no more than 15 mm.
      • If the gearshift lever free play is too great, check the gearshift cables and replace them if necessary.
    • If the gearshift lever free play is OK, adjust the gearshift linkage. For additional information, refer to Section 308-06 .
  1. Check the transaxle fluid level and top up with Automatic Transmission Fluid ESD-M2C186-A if necessary.
Dec 21, 2010 | 1998 Ford Contour
I cannot get the car into gear. It is a manual transmission. Is there a spot where fluid goes in for the clutch?
Your clutch is not hydraulic but is supposed to self adjust. Try the procedure below to help it adjust. If it will not adjust, the clutch may be worn out.
ADJUSTMENT
Free-Play See Figures 8, 9 and 10
The clutch free-play is adjusted automatically by a built-in clutch control mechanism. This device allows the clutch controls to self-adjust during normal operation.
The system consists of a spring-loaded gear quadrant, a spring-loaded pawl and a clutch cable which is spring-loaded to preload the release lever bearing. This compensates for movement of the release lever, as the clutch disc wears. The pawl, located at the top of the clutch pedal, engages the gear quadrant when the clutch pedal is depressed and pulls the cable through its continuously adjusted stroke. Clutch cable adjustments are not required because of this feature.
Fig. Fig. 8: Clutch self-adjusting system component identification for the 3.8L engine
CHECKING ADJUSTMENT
The self-adjusting feature should be checked every 5,000 miles (8,000 km). This is accomplished by ensuring that the clutch pedal travels to the top of its upward position. Grasp the clutch pedal with your hand or put your foot under the clutch pedal, and pull up on the pedal until it stops. Very little effort is required (about 10 lbs./4.5 kg). Finally, depress the clutch pedal and listen for an audible "click.'' If you hear a sound, the clutch was in need of adjustment, and it has just adjusted itself.
Nov 23, 2010 | 1998 Ford Mustang
Info on do it tyour self clutch removal on 2001 mustang 3.8
REMOVAL:
  1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
  2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
  3. Raise and support vehicle.
  4. Remove clutch release lever dust shield.
  5. Disconnect clutch release lever cable from clutch release shaft.
  6. Remove retaining clip, then clutch release lever cable from flywheel housing.
  7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
  8. Remove transmission.
  9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
  10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
  11. Remove clutch release hub and bearing from clutch release shaft.
  12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
  13. Remove clutch pressure plate and clutch disc from flywheel.
INSTALLATION:
  1. Position clutch disc and pressure plate assembly on flywheel, noting following:
    1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
    2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
    3. tart clutch pressure plate bolts but do not tighten.
    4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
    5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
    6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
  2. Install transmission to flywheel housing.
  3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
  4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
  5. Install starter motor.
  6. Lower vehicle, then install clutch release lever cable as follows:
    1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
  7. Cycle clutch pedal several times to adjust clutch release lever cable
Aug 08, 2009 | 2001 Ford Mustang
Craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Car will not drive, is it clutch or cabel
my daewoo lanos wont shift into gear/s while running even when clutch is depressed all the way
Nov 12, 2008 | 2001 Daewoo Lanos
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
167 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
