Question about Belling XOU270 / XOU271 Electric Single Oven
WHY CANT I TAKE ELEMENT OUT
HOW DO I TAKE ELEMENT OUT AT REAR OF OVEN TO REPLACE WITH A NEW ONE. THERE APEARS TO BE 2 LITTLE SCREWS THAT I CANT UNDO DO I HAVE TO TAKE THE OVEN OUT TO GET TO THE BACK?
  • Belling Master
  • 3,463 Answers
If you cannot remove screws from inside oven compartment, then, yes, it will be neccescery for you to remove the oven from it's housing to gain access to the screws from the rear.
Posted on May 04, 2010
My ovena akl887/701 element has gone how do i change it
you should get 18 ohms across an element if its ok swich off cooker remove shelf's normally 4 screws holding on back panel inside oven you can now see element 2 screws hold element in position you may see them inside oven or failing that remove rear panel of oven and undo screws pull off spade connectors refit new element it dose not mater witch way arond the cables go as long as the earth is in the right place if fitted
Dec 09, 2016 | Ovens
How do i replace the element in the bottom oven of an AEG U3100-4 cooker ?
If it is a fan assisted oven, remove the screws securing the rear cover inside the oven compartment, remove cover, and you should see the oven element there.
Undo the element, and fit new one.
Aug 04, 2010 | AEG U3100-4 Electric Double Oven
How to replace element on my Hotpoint main oven BD31
If it is the main oven element, then undo the screws that secure the cover at the rear of the oven, remove cover, and you will see the round element there.
Undo screw securing element, and pull forward in to oven compartment.
Detach the wires, and fit new element.
Hope this helps you.
Please leave feedback.
Thankyou.
Jan 06, 2010 | Hotpoint Ovens
Whirlpool AKZ 446 Electric fan starts but oven does not heat up ?? Is the element easy to replace/fit? Thanks
Yes , the element is easy to replace
Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
This should solve your prob.
Good luck..
Dec 29, 2009 | Whirlpool AKZ159IX Oven
How to fit new element to electric fan oven
The oven element is located at rear of oven compartment, behind a removeable cover.
Undo screws securing cover.
ondo screws securing element, and pull towards you.
remove wires to element, be careful not to lose them inside.
Fit new element, and fasten cover back on.
MAKE SURE THE POWER IS OFF.
Please leave any comments you have, as I like to know if my solution was o/k.
Thanks.
Nov 25, 2009 | Ariston Technologies Ovens
How do I replace the heating element in Neff U1461N2 main oven?
Switch power off first.
Remove the screws that secure the rear cover in the oven compartment.
There you will see the circular element, undo screws that secure element, slówly withdraw element towards you, disconnect leads, taking care not to lose them behind the aperture., fit leads onto new element, and refit element.
Refit cover and test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff U1721 Double circotherm Electric Oven
I want to replace the top grill element in a zanussi zhq 575
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
Main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
Dec 13, 2008 | Zanussi Ovens
AEG U7101-4 Top Oven tripping the fuse after a few minutes
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Dec 12, 2008 | AEG U7101-4 Electric Double Oven
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Belling XOU270 / XOU271 Electric Single Oven Logo
135 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
