Question about Peg Perego John Deere Gator HPX
Need the wireing veiw for hook up for the pettle to make the equipment operate. that relays to the battery connection that goes to the foward and reverse pettle.two reds ,one white one blue (one of the red wire is used for connecting for front and backwards togeather post.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Posted on Jun 08, 2012
5 Suggested Answers
SOURCE: only goes in reverse after recent charging
I would replace the high/low switch and the reverse switch.
I had the same problem of it not going forward, but I just replaced the high/low switch. It turns out 1 month later I had to replace the reverse switch.
Here is the link to the site that I found my switches on.
http://www.shopjandl.com/mepu0003.html
Hope this helps
Posted on Apr 21, 2009
  • 850 Answers
SOURCE: what wire connect to garor foot switch there red
look at the motors wires to check the colours
the foot switch has 3 terminals
1 for reverse is further away from the other 2 [low & high gears]
I hope this helps you!
any dramas feal free to ask me again
Cheers Rob
Posted on Aug 15, 2009
  • 156 Answers
SOURCE: How should I connect the
Hi, you might have fixed this already, but I usually email the repair department at help@mypegperegoparts.com if i need any help with my kids toys.
hope this helps
Posted on Nov 05, 2010
Samir3050
  • 70 Answers
SOURCE: gator wont go
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com
Posted on Mar 02, 2011
Won,t start ..battery was dead..jumped.. Recharged.wont crank
Battery cable connections ? Need to hook up scan tool to see if the modules on the vehicle are communicating ! Voltage drop test starting system . Check START 1 relay in underhood fuse/relay box ! Check PCM/BATT fuse 10amp ! Check power at relay ! This video shows how ! VEHICLE RELAYS Operation Diagnosis If you don't know, best take to a ASE certified technician before you break it ? How to Test and Troubleshoot Starter Problem
Jul 29, 2015 | 2003 Buick LeSabre
How do i find the hot wire on my 2012 toyota tundras ignition switch
To be legal they must not operate when the high beams are on. Use a relay because of the current and connect them via the relay to the battery. Power the relay from the low beam power wire. Be sure you put a fuse in the battery line.
Nov 18, 2014 | Toyota Cars & Trucks
Chevy Tahoe Intermittent No Crank
I will try to help, powell. Your start circuit from battery to ignition switch to starter-and back to battery. You may need to check every thing here, including the grounds, for a loose connection, or just possibly a failing part.
If only complaint is intermittent starter action, and no other problems with ignition switch, let's assume switch is good, so battery to ignition switch is good. Now from the switch, a yellow start wire goes to the instrument panel fuse block, to "crank" fuse #8 (10 amp), from there a purple wire goes to the safety switch. If manual it is a clutch pedal position switch (simple on/off switch-when clutch down switch is on). If automatic, purple wire goes to Transmission Range Switch on the transm.-in park or neutral the purple wire has continuity in and out of switch.
From that switch, the purple wire goes to the starter relay (under hood fuse-relay center). Now the relay: purple wire in start will energize the relay- wire goes to coil side of relay, and then coil side goes to ground. On relay power side, the power feed is a red wire-and it is the same red wire that initially sends power to the ignition switch. A 40 amp fuse in fuse-relay center sends power to ignition switch, and a splice goes to the starter relay as the power feed for relay. When relay is energized, contacts close, and power is sent from relay to the starter solenoid, again on a purple wire. When solenoid contacts close, starter motor is connected to the big battery cable on the starter.
There is your start circuit. try a new or different relay, try a new or test the clutch switch (or transm. range switch). Buy a $5 test light and use it to check where power is lost when starter won't operate. Hold key in start and check if fuse #8 is getting power. Check the safety switch, with key held in start, the purple wire should be hot. Check if relay has a power feed (pull relay out and check terminals) and if relay coil has a power signal in start. Check the relay's coil side ground. If that ground is intermittent, relay won't work.
When it won't start, use a test light, you should be able to find it.
Good luck.
Jan 10, 2014 | 1997 Chevrolet Tahoe
I have a93 f 150 when i hook the pos cable to the battery the starter spins but the battery pos sparks ty
tHE STARTER RELAY is shorted and is stuck in the crank mode. The battery cable sparks because of starter load Relay must be replaced ot at least checked for the two small wires being crossed. One of the small wires on the relay should have current only when key is in crank position.
Remove the two small wires and see if it still cranks when battery is hooked up. If so, replace relay. The + cable goes from battery to relay. Ned
Dec 18, 2010 | 1990 Ford F150
1996 Pontiac Sunfire starter wiring - has had the recall service done to add the starter relay. All of the wires were cut to the starter. Here is what I have so far: The battery wire goes to the large...
I am not familiar with the model or the modification. The relay is required to act as a switch to relieve the load on the igniton/starter switch and the stock wiring. The starter switch now switches on the relay instead of operating the starter directly.
The relay contains two parts - the switching contacts and the relay coil or electromagnet that when energised pulls the switching contacts together or apart depending on design.
For use as a starter relay a standard 4-pin relay would be suitable but a 5-pin could be used without detriment leaving one pin unused.
The wire from the ignition/starter switch will be used to energise the relay coil and therefore switch on the current flow to the solenoid. In order to energise it must be part of a circuit and so current must flow through the coil from the ignition/starter switch and then to ground - the thin black wire is traditionally the ground wire for the relay coil, but you will need to check this yourself.
In order to switch a good supply of current to the starter soleniod the relay switching contacts are connected, one to a battery supply and the other one to the soleniod S terminal. The battery supply could be from the battery or from the large stud terminal of the soleniod. If from the battery or other remote place best practice would be to ensure a suitable fuse is also included. While the relay coil ground wire is traditionally thin the battery supply and solenoid wires traditionally are fairly thick.
Sometimes a relay has a helpful circuit imprinted on the cover. Many relays can easily have the cover removed and once you see inside the way it works becomes failty obvious.
I hope this helps...
Apr 01, 2017 | 1996 Pontiac Sunfire
I need A ignition wiring diagram for a simple hook up on a piece of farm equipment the engine is a 60s straight 6 ford already converted to 12 volt
Run circuit = Key on- hot wire to coil + terminal. Coil-- goes to distributor. Cranking circuit. Hot wire to stsrter relay s post . One of the two small posts. Battery. + to relay +out of relay to starter.Battery -- to engine for a ground. I hope this helps, Good Luck, Ned
Sep 15, 2009 | Ford Econoline Cars & Trucks
I don't understand my wiring diagram.How does the positive and negative cables hook up to the starter relay and to the battery.I have one small red wire coming from my wiring harness does this wire connect...
Hi and welcome to FixYa,
If the starter relay in your version uses blue / white and red / white wires, then to my understanding, connection would be:
  • blue / white - goes to the start switch and is supplied with +12 on starting;
  • red / white - goes to the starter circuit cut-out relay. This cut-out relay controls whether the starting relay gets a ground based on neutral/gear and clutch lever conditions.
Good luck and thank you for asking FixYa.
Jul 08, 2009 | 1985 Yamaha XJ 700 X Maxim
1985 Yamaha xj700 Maxim-I am confused about my positive and negative cables.I have a red wire coming from my main harness and a cable on the positive side of the battery does the red wire and the red cable...
Pls see your other post, but basically:
  • in most, one end of the red wire is connected straight to the battery's + terminal. The other end of the red wire goes to the main fuse;
  • the black of course as you posted goes to the ground;
  • interchanging the 2 wires from the starter relay would make no difference;
  • the starter relay is not directly grounded;
  • the starter relay's + wire goes to the starter button;
  • the starter  relay's - wire goes to starter cut-off activated by safety interlocks (neutral and clutch lever).
Jul 08, 2009 | Yamaha XJ 700 S Maxim Motorcycles
My subwoofer drained the battery to the car over night
I am not sure how you have it hooked up, but the amp should be connected with heavy gauge wire to a relay that goes straight to the battery for the best current flow. The coil of the relay can be connected to the power output wire of the stereo (usually blue) or to a switched circuit. When the ignition is switched on or the stereo is turned on (depending on which you have it connected to) the power to the relay coil will connect the power from the battery to the amp. When you turn off the stereo or ignition, the power to the relay coil goes off and the spring breaks the circuit at the contactor. You can buy a relay at any auto parts place. Make sure you ground the amp near where the stereo is grounded or you will get a whine in the stereo from a "ground loop". Please don't forget to rate this solution.
Apr 15, 2009 | Fusion FEW12PK Car Subwoofer
Peg Perego John Deere Gator HPX Logo
63 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
