Question about Hotpoint 30" Self-Cleaning Freestanding Gas Range - Black
Hotpoint RGB745 Gas Kitchen Range display shows "bad line" and beeps while plugged in. None of the control panel operations function and the electonic ignition does not work. This happened immediately following a lightning strike near the house.
  • 2 more comments
  • stephenhawks May 04, 2010
    The electrical outlet the stove was plugged into works. I can plug in small appliances and they operate. The electrical panel does not show anything switched off; everything is in the on position. Never lost electricity to the house on anything. It seems to be limited to the stove display panel.
    This stove has worked with the existing electrical system for five years when I upgraded my service and had a new electrical panel installed by a licensed electrician which passed code inspection. This is why it does not seem related to my electrical system at my level of understanding. Why does it seem that way to you?
    I received no further comment to the information provided an hour ago. I assume the expert has nothing further to add. But I want to nail down whether I need a stove repairman or an electrician.
    If this was your stove, would you call a Hotpoint stove repairman or an electrician?
  • 668 Answers
This tends to be the problem due to power surge which has been caused by the lightening .The circuit breaker might have been damaged also chance that the fuse inside kitchen range is blown . If fuse is bad then ignition won't work properly .You need to replace with new one .
Hope this helps .
Posted on May 04, 2010
  • Shane May 04, 2010
    You need to call electrician to check all the connections are fine .
  • 713 Answers
The problem is from the electricity supply into the range,the lightning has affected your house wiring which has affected the power supply,the problem is not from your range,take time to conduct a thorough check on the wire and sockets and the junction boxes that supply electricity to the gas range,that's where the fault is.
Thanks and take care
  • Oyelade Gbenga May 04, 2010
    the electricity supply is not up to the desired voltage of the range
    sorry,i had to attend to other pressing issues,the problem you are encountering can be solved by an electrician,i'm absolutely sure that your gas range is in a good shape,you need an electrician
I plug my gas stove in and the display says bad line and beeps steady
"bad line" error means the control panel is not seeing a proper voltage to the oven. Have the power connections checked with a voltmeter all the way to the control panel. If voltage is present, you may need a new control. 25316221-dz1fkxf1fwolart5ai0divhk-4-0.jpg
Dec 10, 2014 | Hotpoint RGB745 Gas Kitchen Range
Why does Control panel constantly buzz on a HotPoint RGB744 and RGB745 whenever it is plugged in.
Could be a faulty solenoid coil on the gas valve, or a relay you may need to remove the front panel and have a listen be careful it's live power . Use a multimeter to test through the circuits an disconnect the item that's buzzing, there is your problem.
Good luck and be careful
Ray
Jun 03, 2014 | Hotpoint RGB745 Gas Kitchen Range
How do I perform the self cleaning function for my Hotpoint Gas range RGB745?
Press the self clean button, move the latch to the right (this locks the door) then push start, it will take 4 hours and 20 min, let the glass cool before you clean it after self cleaning
Jun 11, 2012 | Hotpoint RGB745 Gas Kitchen Range
What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
May 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
Hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Oct 23, 2008 | Hotpoint RGB745 Gas Kitchen Range
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Oven not working
Something wrong with knob , the adjustment i s still in close position , and cover with warranty period let them fix the adjusment by company where you bought it.
May 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint 30" Self-Cleaning Freestanding Gas Range - Black Logo
66 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
