How to set up dual boot for two hard drives?
I have a friend's computer with two hard drives installed. I would like to set it up for dual-boot so that she will have the choice of which drive to boot on.
• One drive has Windows 7 Home Premium 64-bit and came with the new computer
• The drive from her old computer has Windows XP Home Edition 32-bit
• Computer is a HP Pavilion p63101 with 2GB RAM
When I received the computer both drives were connected and apparently the old XP drive was set as the primary. When I booted it up the first time the USB mouse and USB keyboard would not work and there was an error message that stated that Windows strongly recommended not continuing with the installation of the drive because it had not passed some compatibility test.
I disconnected the power from the old drive and removed a red cable from it that was connecting it to a SATA port on the motherboard.
I rebooted the machine again and it successfully booted into Windows 7. Everything has worked fairly smoothly to this point.
My friend wants the computer to be able to boot into XP so that she can continue using an ancient printer that has not been supported for years (ALPS MD-1000). Because of the error message I was seeing before I am hesitant to try and reinstall the drive. Also, I am not certain how to set everything up to allow her to boot into the OS of her choice.
  • 22 Answers
My freind, you can boot from two hdd inside the same computer. You can only boot from the primary HDD. What you need to do is install both Windows 7 and XP on the primary hdd in different partitions. Then when you boot the system it will give you the option for booting to both XP and 7. You dont even need the secondary hdd unless you are looking to have more storage space.
Posted on May 04, 2010
Can I override the bios at startup so that it will recognize a new hard drive - for linux?
There should be no need to play around with your bios settings. Linux will install on a brand new hard drive as the sole operating system, or on an existing hard drive alongside Windows without any problem.
If you haven't already got a Linux distro, have a look at
http://www.ubuntu.com/download/desktop
Download whichever version of Ubuntu you prefer (LTS- the long term support version is recommended).
When the .iso file containing the operating system had downloaded, burn it onto a dvd, or install it on a usb drive.
Insert the dvd into the drive and restart or switch off/switch on the computer. The dvd will then kick in and offer you the choice of trying Ubuntu without installing, or a full install.
If you're using a new, empty hard drive just follow the on screen instructions and Ubuntu will install as the sole operating system.
If you already have Windows on your hard drive Ubuntu will give you the choice of either erasing Windows or installing Ubuntu alongside Windows. It's your choice.
Installing Ubuntu alongside Windows creates a dual boot hard drive. At start up you just choose which OS to use - Windows or Ubuntu. If creating this dual-boot system Ubuntu puts a (Linux) boot loader into the Windows OS so that Linux is recognised.
If you save the Ubuntu file to a usb drive you then have to change the bios settings so that your computer uses USB as the first boot device. Then restart your computer so that it boots in from your usb .. and Ubuntu will begin installing.
Whichever you use - dvd or usb - during the installation process Ubuntu will ask you how many GB of hard drive space it should use? You do not need to physically partition the hard drive. Linux will do it for you.
If it's a desktop PC you are using with Windows on the first hard drive and are fitting a second hard drive to install Linux on, or have installed Linux on the second hard drive .. and find that Linux doesn't appear at start up, it's because there's no Linux boot loader in Windows.
I quit using Windows many years ago.
Nov 01, 2015 | Everex IMPACT GC2500 PC Desktop
I have want to setup Windows xp and windows 7 together .Meaning when start up computer have : Windows xp Windows 7 I try to setup two windows ,but i setup windows xp lost windows 7 and setup windows 7...
Not sure what you have done so far. You need to divide your hard drive into two sections. Install XP first on to one section. Then use a program to manage your computer start up, the one I use is called Easy BCD this is a free program and works great. Once you cut your hard drive and install XP make a copy of your start up partition. Install the Easy BCD program and make a back up again. Then Install Win 7. Then on the Win7 side install the Easy BDC program and set up the menu choices. I run a 3 way boot with XP and Ubuntu. Hope this helps Fix Ya up.
Jul 09, 2011 | Computers & Internet
Dual Boot
I am assuming they are both internal hard drives, If this is the case, on the back of the hard drive itself, there will be a set of pins with a little plastic connector in between two of them. This connector selects the role of the hard drive.
You want to set the Hard drive which has the operating system installed on it to MASTER and set the hard drive you want to use for extra space as SLAVE.
This tells the computer which hard drive to actualy boot from. It is not possible to run to Operating systems at the same time.
Nov 18, 2009 | Dell Dimension 2400 PC Desktop
How to: Dual Boot system with XP & Vista on separate hard drives
If XP where your primary OS this would not be a problem. Since Vista is the Primary you are going to need to get a boot loader that will start before either OS does and use that to choose OS at bootup.
Sep 12, 2009 | Dell Studio XPS Desktop Computer
I need to setup a dual boot computer. I have 2 hard drives each has an os I need the option to select at startup
Try Install KDE on your desktop, I think its much better than gnome for booting setup. There's another way which one you'd like to booth by striking the F8 key repeatedly on the restart or starting your PC and select the drive which drive you like to boot.Or you can configure it on your bios setup by hitting the del key and configure your boot priority.
Sep 11, 2009 | Microsoft Windows XP Home Edition
Dual Booting
Yo u cant dual boot without restarting the machine unless you use virtualization technology ie virtual pc or vm ware
Regards Al
May 26, 2009 | AMD Athlon , 750 MHz Processor
Hard drive installation problem
Yes it is possible but you need to set it up as a dual boot system with XP installed on the 2nd drive (slave drive).
Mar 16, 2009 | HP Compaq nx6110 PC Laptop
It possible to run 2 differant os on 2 differant hd on 1 compute
to be honest, im not sure if its possible....you can only do it using dual boot but it only uses a single hardisk with 2 separate operating system.
how to make a dual boot can be found here
supported dual boot configurations here
if you need more information, please let us know
Feb 07, 2009 | Maxtor DiamondMax® 6800 10 GB ATA-66 Hard...
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
I am having trouble with the hard drive I think
the first thing that u replace the hard drive right from ur pc to the one u got from ur friend>what happend is ur hard drive is configured for ur mother board>and the mother board of the pc that u got from ur friend is configured for the hard drive so u can not use ur hard drive untill u format it
Oct 14, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
