Question about Kohler K-12265-4-BN Fairfax Lavatory Faucet with Lever Handles - Brushed Ni...
Cold water side is jammed and extremely hard to turn on and off What is possible cause and fix?
  • 349 Answers
Take stem out and inspect it should have a slot on the side of it to how it slides down into faucet. and packing nut on top that holds stem down may be to tight you can use a wrench and back off of it a little first to see if it will take care of problem.
Posted on May 05, 2010
No water going into powder drawer. It's going from pipe to machine then doesn't go anywhere. Also just makes humming noise!
Hello. Are you on well water by chance? From what you describe, the inlet water supply filter screens are clogged. Turn off the water supply to both hot and cold. You will have to remove the water lines from the back of the washer--don't get them confused. Use a dish towel to catch the small amount of water that will burp out of the lines due to the release of pressure in them when removed. Now, using a flashlight, look into the cold and hot water connections--there will be(there had better be) a fine wire mesh filter or a plastic filter in each water valve. If the filters are clogged, carefully remove them--be especially careful not to tear the wire mesh or crack the plastic depending on the type. These filters keep the sand, sediment, or other debris out of the precision valve mechanisms. Most likely, the cold water filter is clogged and is causing the symptom you describe. Rarely does the hot water side get clogged because the water first goes into the tank, then into the water line to the washer. Most, if not all, sediment drops into the tank instead of going directly to the back of the washer like the cold side does. Usually, the problem has been building up over time with the cold water just trickling into the washer. On all the electronic controlled machines, there is a built-in time limit for the unit to get a certain amount of water so the computer can start the cycle. If water is entering too slowly, the computer will error code out or strange symptoms might occur due to the lack of sufficient water. If the filters are clear, then you most likely have a jammed water valve and it will have to be replaced. The valves can come separately or as a single unit depending on the make/model of your unit. DON'T EVER USE YOUR MACHINE WITHOUT THOSE FILTER SCREENS. The machined valves will become jammed extremely quickly. I hope I helped you!
Sep 26, 2015 | Washing Machines
My side by side ge profile refrigerator is causing grief. It starts by water freezing not allowing the water dispenser to work. Then it begins to defrost the freezer side. I also notice that anything in...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 23, 2011 | GE Refrigerators
Frigidaire side-by-side water & ice in the door Model #GLRS234ZAW1. The refrigerator side freezes with its thermostat any where above the lowest setting. Also the freezer thermostat has to be only a...
Leo Ponder
imufo2
Sep 22, 2011 | Refrigerators
Frigidaire GLRS237zcbo Everything is frozen on the fridge side, turned temp up but no change?
Leo Ponder
imufo2
Sep 12, 2011 | Frigidaire FRS23KF7AB Side by Side...
Hot water is a small trickle into the machine - warm water gives you a bit more water coming into the machine & cold water has a moderate bit of water coming into the machine. We have extremely hard...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 01, 2010 | Frigidaire FWS833A Top Load Washer
Cold water flow is extremely slow. have checked
REMOVE THE COLD WATER HOSE FROM THE WASHER, AN LOOK INSIDE THE VALVE, AN CHECK THE SCREEN, FOR BLOCKAGE, SPECIALLY IF YOU HAVE HARD WATER IN YOUR AREA.,
I HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | GE Profile WPRE6100G Top Load Washer
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
2005 Honda civic: when the AC is on water leaks to the passenger side floor and a squeal noise is heard when the car makes a hard left turn.
The squeal, first:
Noises are difficult to diagnose without hearing them in person. There are too many potential causes; maybe the power steering pump (turning the wheel to lock causes this), maybe tires, maybe a cv joint.
The A/C water is condensation that occurs because of the cold. This is perfectly natural and is a sign of a very cold-blowing A/C unit.
Regards,
matt
Sep 14, 2009 | 2005 Honda Civic
Water Heater Won't Fire up
does the fan come on? this has to happen before it will even try to start if it doesn't your problem goes farther into the unit,, normal pracess if the fan then the ignitor then the flame, It could be in the circuit board most people that have gone with the tankless don't clearly ask the question but that is normal, but if you could clearify the procedure of what it is doing to this point i could be more helpful to you---- e-mail me what is happeing diffrent then what it use to do gary1121@aol.com
Jun 01, 2009 | Noritz 6.3 Gallon Residential Tankless...
Kohler K-12265-4-BN  Fairfax Lavatory Faucet with Lever Handles - Brushed Ni... Logo
146 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
