Question about Xerox WorkCentre M20i All-In-One Laser Printer
Xerox work center 7132 will not boot up. error code (092-310). It says shut down printer and turn it back on. but i did that cuople of times still the same error code. it says contact service if error persist.
    Scholar:
  • 92 Answers
Try to unplug the device directly from the socket wall and leave it for 5min. Plug in again. If message still occour it could be related to 2 reasons.
1. Sensor problem leading to "ghost" message -- require eng.
2. Toner replacement also causes this message.
Even if you do couple of boot routines you might want to have someone onsite to have a look at it. It might require parts.
Posted on May 05, 2010
How to clear error 10-333 on xerox 7132 all in one
That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
http://www.iteminconline.com/008r13022_008r13022-xerox-workcentre-7132-fuser-110-volt.htm?source=froogle&gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzZg4C5Qd7jYhL14rJSJWIPdkZdVrtP4kPg2RlOQFweIaAnzV8P8HAQ
Apr 26, 2015 | Xerox Office Equipment & Supplies
How do i get get rid of 010-330 code on a xerox 7132
We encourage you to use our knowledgebase, MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year!
We can solve your problem!
Email patrick@mrc360.com for more info. Solutions for : Fault Code 010-330: The Fuser Motor is Not Rotating at the Specified SpeedMessage Related Fault Code: 010-330 Solutions ranked by relevance:
  1. Power the Machine Off and On
  2. Remove and Re-install the Fuser
  3. Replace the Fuser
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=468,E=0000000000016144604,K=4237,Sxi=2,Case=obj(3468)
Oct 07, 2014 | Xerox Work center 7132 copiers
I have changed the image drum i now have error 092-310
This code indicates a failure in the ADC Sensor circuit. Fixing it does not seem to be for the faint of heart . If you are feeling brave check out this thread:
http://www.copytechnet.com/forums/xerox/21835-xerox-7132-error-code-092-310-a.html
Sorry I could not offer you a definative solution directly.
Oct 31, 2013 | Xerox 6500/N Phaser Laser Printer
The Windows 7 mini drivers for the Xerox 7132 only provide a limited feature set. If I install the Windows 7 driver for the Xerox 7232, will it work with all features on the Xerox 7132?
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=WC7132&ripId=&Xtype=download
The above is the XP Vista drivers for the 7132.
The 7232 is a totally different machine and the windows 7 drivers for it will not work with your 7131 according to their table.
Also, according to Xerox's table, windows 7 drivers are definitely not available for the 7132. The latest drivers are for Vista, but that's not necessarily a bad thing, because windows 7 can run vista programs in its compatibility mode, or many times it works alright after downloading and installing the vista drivers.
Hope this helps!
Jul 14, 2010 | Xerox WC7232 Printer
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Xerox WC 7132 printer error code 016-601 error and error type illegal access detection
  1. Click on the "Configuration" tab
  2. Choose the account mode to "User"
  3. Click on "Detailed User Settings"
  4. Change the password details as per instructions from your printer administrator
cFor more help visit cbrtechsolutions
Sep 04, 2009 | Xerox WC7232 Printer
Fault code 010-333 xerox 7132
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
Aug 13, 2008 | Xerox Office Equipment & Supplies
Xerox WorkCentre M20i All-In-One Laser Printer Logo
824 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
