Question about Gateway Photo Jukebox GCM-4 MP3 Player
I get an error that says HDD init failed connect to pc when my computer doesn't recognize it so I cannot format the HDD?
The main hd is unpluged. Unscrew the screws nezt to battery. Slide left the back cover just like the battery cover and plug the hd back in. piece of cake!
Posted on Sep 12, 2010
Trying to start computer with SSD and HDD, NOT happening!
Have you tried going into the bios to see if the ssd is recognized and have the computer boot from the ssd So connect the drive and put your windows disk in and install to the ssd During the install it will scan for drives and ask which drive you want to install on Make sure you check the boot options in the bios to allow the connect drive
Nov 23, 2012 | Computers & Internet
My new Sony DCR-SR68E shows hard disk format error and E:31:00 error every-time I star it. It doesn`t shoot anything. It doesn`t even get formated. Please let me know if there is anyway to solve this...
SonyDCR-SR68E HDD Format error
Go to Menu-Show Others-Media format-HDD-Yes-Yes-ok
you must be solve your problem.
Never format your camcorder with NTFS or FAT system format using your operating system Windows.
Sep 18, 2011 | Sony Handycam DCR-SR100 Camcorder
I have what I think is an Inoi Sata multimedia hDD ( Square aluiminum case) .I have connected it to a Windows 7 computer and has failed to be recocognised. Where do I find suitable drivers thanks
you should not need drivers for that all, windows should be able to recognize it.
These things usually need an external power supply, first check if it is connected.
Try it with a different computer. If it works then I suggest a system restore on the other comp.
If it doesn't work (which is likely) then you should take apart the metal case, remove the HDD (which is a totally standard desktop HDD) and plug it inside the comp with the SATA port. Windows then will correct the disk errr upon turning on. If it doesn't work this way either then it's dead. If it works flawlessly, but when put back into the case it doesn't wok again then the housing is faulty.
Aug 11, 2011 | INOi HD370 300 GB USB 2.0 Hard Drive
Hitachi 320gb hd is recognized. I try to write as back up. It does not write
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 24, 2011 | Computers & Internet
I have an Acer Extensa 4620z, i can't load the OS, i've tried with XP and Win7 and there's an error, i tried to change the setings in BIOS, but there's not any option to change anything about the SATA or...
yes quite right.. when u start the install process I'm sure you noticed that it asked you to press F6 to install any 3rd party RAID / Sata drivers.. these can be downloaded from the manufactures web site..
what concerns me is that windows 7 Ultimate has these drivers built in!!! did u try windows 7 ultimate ???? not the OEM version that ships with systems ,, use a full version..
also DO a full format not a quick format.. when win 7 or xp instillation boots,, delete all partitions and do a full format..
if that fails u need to replace the hardrive,, A dead harddrive will give the same error!!!
Sep 14, 2010 | Computers & Internet
While transfering a file from pc to hd computer froze. I then unpluged the drive and then pc come back to normal now the external will not get recognised
It sounds like you have a serious problem. If you cannot get the HDD to read at all and your computer will not recognize it, you have a bad "sector" of the drive.
As a metaphor:
Your drive has little "squares," each square stores information on it. Your computer will break the data down into these squares and store it in segments. When your computer freezes its because it is "confused" as to why it cannot store the data. When you remove the HDD, the computer then assumes it's to stop and resumes regular activity.
The solution:
A) Go to “My Computer” right click on the Hard Drives icon and go to “Properties,” then go to “Tools” and then to “Error Checking.” Also then “Defragment”
If that doesn’t work:
B) Try to reinstall the updated drivers on the manufactures web-site. After you have reinstalled the drivers reformat the Hard Drive. Reformat your hard drive by going into "My Computer" and right clicking the HDD and selecting "Format." Follow the prompt.
-Paul
May 21, 2010 | SimpleTech Signature Mini 250GB External...
Computer doesn't recognize hard drive
If your hard drive is not recognize by your computer try to enter cmos set-up and see if your HDD is detected and if it is detected by your pc then you probably have error in your MBR, try to format your hdd using fdisk. If this doesn't work you maybe have a faulty HDD, try to replace with a new one to try if your HDD is really the problem, also replace your data cable (IDE/SATA) maybe that the problem. good luck with this.
Jun 12, 2009 | AMS VENUS DS3 Aluminum Black 3.5" External...
PHYSICAL IP ADDRESS NOT RECOGNIZED, IT JUST SAYS FF-FF-FF-FF, AND DOESN´T RECOGNIZED THE IP ADDFRESS FOR THE INTERNET CONNECTION?? PLEASE HELP, DO I HAVE TO FORMAT MY COMPUTER OR I JUST NEED A DRIVER?
Update the O/S first
Check the connection is DHCP
control panel,network connections, right click your connection to the internet, properties,
TCP/IP VER4, highlight this in grey, click properties,
should be set to
( obtain I.P. automatically ) tick this box.save it.
Reboot the system.
hope this helps
Regards
Apr 19, 2009 | Toshiba Tecra M2V-S310 Notebook
Dell Desktop computer Disk read error
try running Hard drive diagnostics from either the F12 menu or CNTL+ALT+D at Dell BIOS splash screen
Most likely, failed HDD
Jan 29, 2009 | Dell OptiPlex GX260 PC Desktop
Gateway Photo Jukebox GCM-4 MP3 Player Logo
100 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
richie46
ptpumpman
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
