Question about Hyundai ImageQuest ImageQuest Q770 17" CRT Monitor
Hyundai q770 stuck on off mode it comes on then turns off displaying the message OFF MODE
98 Oldsmobile Aurora There's a on my Dash it says information center and has the oil fuel speed all that it says low oil is there any way anybody knows how to reset that
Check your engine oil using the oil dipstick located on the engine - you need to add oil to the fill line as shown on the dipstick. You should have the oil replaced regularly (every 3-6 months) and keep your eye on the level if the engine is leaking oil underneath or burning a lot of it.
Mar 08, 2017 | Oldsmobile Cars & Trucks
How to reset the oil life light on 2013 Hyundai Sonata
o reset the 2013 Hyundai service interval, please follow these instructions to reset/setup:
1.Start the engine.
2. If a service is due the display will show "Service required".
To reset this message, press the SELECT/RESET button (left
pointing arrow) on the bottom right of the steering wheel for more
than 1 second.
3. The service interval will be reset to the default setting.
*The service interval feature has to be turned on and set by
the user by accessing the SERVICE INTERVAL menu. Press
the MODE button (rectangle icons) on the bottom right of the
steering wheel to highlight the SERVICE INTERVAL menu.
Press the SELECT/RESET button to access the menu and
use the DOWN arrow to turn the SERVICE mode on and
set the applicable interval.
4. Turn the ignition off and then start the engine to verify the
indicator has been reset.
- See more at: http://oilreset.com/2013-hyundai-santa-fe-service-interval-reset/#sthash.MniBNaqR.dpuf
Nov 30, 2014 | 2013 Hyundai Sonata Limited
1993 hyundai sonata has check engine light on and is stuck in limp mode and wont shift out of second gear
the .pcm puts it in limp mode and it will stay in mode until light is turned off. You need to get the trouble code, repair it, erase the codes (with a scanner that retrieves the codes), and then you will be out of limp home mode.
Mar 23, 2014 | 2001 Hyundai Sonata
Firmware won't update on magicolor 1690mf. pc can't find printer
Have a tech come out re-flash the copier OS. Firmware is only available thur secure web site
Dec 25, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Nokia 6700s stucked in offline mode
You will need a new SIM card. Contact your phone service provider and explain your issue and that your SIM is locked out. You should be set once you tell them that the SIM failed message was coming up.
Oct 26, 2011 | Cell Phones
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
Jun 10, 2010 | Sony STR-DE445 Receiver
Screen saver displaying unwanted message
This happens on monitors with a sleep type function. Make sure that the sleep mode is turned off and that it is set to never turn off inside of windows. Then the no signal error should not come on again.
Sep 07, 2009 | Computers & Internet
Help pls
A possibility is that the VIDEO selections you have made are too acute for the screen and Windows cannot continue (nor can it tell you it can't) so press F8 key while booting, select 'Last known Good' and see if that flies. Last known good is the settings for your PC that worked last time you booted. If that does the same thing, then reboot using F8 again and select 'Safe mode'
This will force WIN to use only known good settings, and then you can fix the problem by START, RUN and typing 'compmgmt.msc', choosing 'Devices', clicking the little + by Display Adapters, highlighting yours and hitting the DEL key. This will remove it and its settings from the Registry (but not the HD) and force Windows to reinstall and reconfigure it
Hope that all helps!
Cheers
Apr 08, 2009 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
REGULATOR
The regulator ic is lm7812 series lm no matter replace it or 12v regulator
Nov 26, 2008 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
Store display mode?
This is a common fault with samsung phones , you will need to replace the keypad with a t6 torx screwdriver or you might need a special kind. message me for details if your stuck. Hope i helped
Feb 15, 2007 | Samsung SCH-a670
Hyundai ImageQuest ImageQuest Q770 17" CRT Monitor Logo
170 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
