Question about DCS FSF-40 Deep Fryer
Fryer keep shutting off
I light the pilot but it is not staying and when it does it only stays lit for about 2 min it will not hold the flame for more than 3 min
  • joedabtx May 04, 2010
    i do not know what that is and i do not think that is it it has done this before it seems like it need to be reset somehow and i do not know how to do that
  • 674 Answers
You need to start with the thermocouple or flame rod that senses if the burner is lit. If it is a flame rod you can probably get by with cleaning it with some still wool. Make sure it is in the flame if it is a flame rod. If its a thermocouple it should be close enough to the flame to get hot.
Posted on May 04, 2010
  • Brian Niten May 04, 2010
    You should be able to see the thermocouple or flame rod near the pilot light. They can go bad over time which is why it can just start happening. A flame rod will look like a metal rod with a wire attached to it. A thermocouple will look like a small bulb with a small copper tube leading from it to the gas valve.
  • Brian Niten May 05, 2010
    Did this help any? You haven't responded anymore. I need you to rate my solution please.
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
How to light the pilot
From looking at this parts list, I see that the gas valve is powered by a thermal generator. The generator holds open the gas valve AND operates the gas valve solenoid. Their are 2 thermostats one of which determines the desired cooking emt and another which is a limit that kills the operation if the oil exceeds 450 f. To light this puppy you move the gas valve selection knob to the PILOT position. Press in on the knob and light the pilot with a match. Keep holding down the knob till the flame stays on without the knob being pressed. Advance the knob to the ON position once you have the pilot lit. Most common problems for this rig: Bad thermal generator/thermopile. Weak thermal generator holds the safety pilot on till heat is called for then shuts down when the solenoid is energized. Bad solenoid operator on gas valve (non replaceable you must buy a new valve) Bad thermostat or limit. Pretty easy fix if you like getting greasy. LOL
Aug 29, 2012 | American Range AF45LP Deep Fryer
Fryer wont stay lit, only two burners will lite, and will only stay lit for about 5 min. will then go out and must start over
Check the gas pressure, it must meet the standard gas pressure written on the nameplate. Check also the quality of pilot flame, poor pilot flame quality will not properly heat up the thermopile which in turn will result in poor fryer operation.
Jun 15, 2011 | Pitco Frialator E24 Deep Fryer
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Pilot light keeps going out! Will not stay Lit.
Check if the the gas pressure is sufficient (as stated on unit's nameplate). Check if the hi limit device is good. Check also if the thermopile (cylindrical metal with two wires standing behind the pilot hood) is receiving enough heat from the pilot flame. The voltage generated by thermopile should be 500millivolts in order to open pilot and main valve. If there is 500millivolt on gas valve thermopile and the pilot flame does not stay lit, you have to replace the gas valve. If the thermopile is glowing red and the voltage generated does not reach 500 millivots, you have to replace the thermopile.
Jan 18, 2011 | Pitco Frialator SG18S Deep Fryer
My pilot light will not stay lit. I have replaced the thermocouple and still will not stay lit. Can the valve be bad?
Make sure the thermocouple is deeper into the flame of the pilot light. It needs to reach a high enough temperature to produce a high enough voltage to keep the pilot light lit all the time. I do not think that the main gas valve is bad at all.
Nov 25, 2010 | Frymaster Dean SR42G Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
Mar 03, 2017 | Desa International CBN20T Heater
Piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
Nov 12, 2009 | Frymaster Dean GF14 Deep Fryer
Pilot light will not stay lit
use a torch to simulate pilot flame and read milivolt. if ok then make sure pilot flame is fully contacting thermopile. also make sure thermopile wiring connections are clean and secure.
Jul 16, 2009 | Imperial IFS40 Deep Fryer
DCS FSF-40 Deep Fryer Logo
247 people viewed this question
Top DCS Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a DCS Kitchen Appliances - Other Expert? Answer questions, earn points and help others
