Question about Kinyo PS-205 Computer Speakers
Appropriate voltage for PS-57
Can you tell me the voltage for computer speakers PS-57 multi media two speaker system - as well as the instruction manual as I can't see it listed. Thanks. Peter.
  • 3,083 Answers
Speakers don't use a voltage level to determine their usage- they use an "ohms" rating, like 4 ohms or 8 ohms. Ohms is written as an omega symbol. You have to match the ohms rated output of the computer to the speakers, or you can either blow the speakers up, or overload your amplifier and burn something up (usually a transistor). The power rating is also used to match components (expressed in watts, or the letter W). You can use a higher power rated speaker with a lower power rated amplifier, but you have to be careful of the opposite case. At some point at the upper end of the volume knob, you will draw too much current and blow the amplifier. Most people do this because it used to be that loud, etc., but in reality, you will never get the same volume with a lower power rated speaker system, and trying to will jepeordize your amplifier. I searched the net, but noone had any technical info on them, but I did see some pictures. My guess is that they're 8 ohm speakers with a very high power rating. Just make sure your amplifier is rated 8 ohms too, good luck! (P.S. if you're amplifier is rated 4 ohms on the output, I would recommend getting an 8 ohm output amplifier on ebay, in the event the speakers are 8 ohms) Hope this helps.
Posted on May 04, 2010
Kinyo ps-56 ac adapter
My kinyo ps-56 works in 7,5 v.
Hope helps
Apr 04, 2013 | Kinyo In Box 2 Ps-56 Multimedia Speaker...
Have a JBL Encounter 2.1 Multi Media Speaker System need to find a power lead and speaker jack for it im resident in uk and need voltage requirements regards
you shouldnt have to worry about a speaker jack for it. it should work anywhere and a simple usa to uk power adapter will work for you it just changes the plug type and up or downs the voltage (i cant recall if uk is higher or lower then the u.s)
Mar 23, 2011 | JBL Encounter 2.1 Computer Speakers
Hey my sound will not work on my media players? any help?
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 24, 2011 | Cybernet Systems CA-3080, CYBER ACOUSTICS...
Como hago para conectarlo directamente al televisor? no me da sonido
Home speaker systems experience malfunction either because the music being played is inappropriately recorded. First attempt to select from the list of media music or video to ascertain the condition as recording related. Second, the adjustments on the media player equalizers mentionable as bass or treble of teeters audibility makes the type of sound preferred. Open to display the computer media player to select from the audio sound adjustment qualities. Most computer media players have auto sound adjustments either mentionable as jess, pop, reggae, as only mandible examples of regulating the sound quality features. Navigate through the media player to ascertain the most appropriate volume; sound ratios require achieving pleasant listening experiences. For example, ascertain from the speakers systems for any available volume adjustment buttons. Also, the media player has adjustments to volume where the computer task bar area has adjustment volume bottoms. Observing queenly the sound features on the computer repair restoration functionalities.
Feb 02, 2011 | Cyber Acoustics CA-5001 Computer Speakers
My speaker system was humming loudy and now only makes a loud static noise.
you might have to uninstall then restart your computer then reinstall both the drivers and the sound devices
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
or
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 02, 2011 | Altec Lansing AVS 500 Computer Speakers
Sound comes out of all speakers but the sound from the left speaker plays through the left, right, and sub. instead of just the left speaker. so i have guitars coming out of the sub and bass coming out of...
you might have to select stereo speakers in the drop down list
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
dont forget to vote
Jan 31, 2011 | Kinyo PS-107 Computer Speakers
What IC that is used in the boka 1050 multi-media spesker?
Ok, I will help,
Please respond to this using COMMENT or REPLY
Hello, can you please tell me what your attempting to do?
Jan 13, 2011 | Boka 1050 Computer Speakers
I have pluged all speakers but not sound on the front and rear to working when i play test they all working but not when i open a music from windows media player.
if your computer came with a motherboard disk the sound drivers could be on it
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | Logitech X-530 Computer Speakers
Plugged them in and no sound they want net me go to volume control
hope this helps
Oct 19, 2010 | Kinyo PS-205 Computer Speakers
I have no sound from my Multi-Media Alaska ms 691 speakers.
make sure that they are plugged in to the right connection in the back of the computer, this jack is usually color coded light green.
Aug 06, 2009 | Bose Companion 5 Multimedia Speaker System...
Kinyo PS-205 Computer Speakers Logo
201 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
