Question about KitchenAid KGSA906P Gas Kitchen Range
Oven shur off during self clean cycle
Power went off and door locked shut. Heard it is a thermostat issue but I see that there are 3 thermostats on this model:
2 on the cooktop and one at the back of the oven. Which one should I order if this is the problem? Is it easy to replace?
  • KitchenAid Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on May 14, 2010
Why is the oven stuck with a "Door Locked" error?
Just guessing but did you just use the clean cycle???? During clean, the oven temp gets high enough to trip the door lock safety thermostat. This is to keep owners from trying to open the door when oven is too hot from clean cycle. It sounds like that safety didn't reset to normal when it cooled off and therefore the door is still locked. With door locked you may need to get oven out of the wall and remove top cover to get to the lock system and thermostats. Make sure power is off before doing any of this.
May 02, 2015 | GE JKP30WMWW 27" Built-in Single Electric...
We have a Kitchen Aid KEBC147VBL03 wall oven. When we ran the self clean oven (big mistake), the oven shut off and locked. There is no display/lights on the control panel. And, the door is stuck in lo
Does the control board or anywhere of control panel have a fuse? If not beter have it service. Expect a quotation from the serv. Tech after it found how big or expensive theparts tobe replace to make ur unit operational agian
Sep 22, 2014 | Ovens
I started a self clean on my oven, and then shut it off, the door opened, now it will not close, seem like the latch is in the lock posistion. help
For an oven self cleaning problem, the first thing to check is the door lock motor and switch assembly. Every self cleaning oven door has a locking mechanism to prevent the door from being opened during the cleaning cycle. An oven self cleaning problem often happens after a clean cycle has been run. If that happens, more often then not the lock assembly will need to be replaced. The door lock motor and switch assembly, over time, fail due to the high temperatures that are encountered during the cleaning cycle.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 02, 2013 | KitchenAid KGRI801PBS Gas Kitchen Range
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
During selfceaning cycle F5 and beeping occured, removed power and powered back on and it seems to be ok, however I haven't tryed the self cleaning yet.
possibly a door latch issue depending on your brand , this is common during self clean dont self clean unless u have to those ovens get close to 1000F so melting of some parts is inevatible.. did it flash f5 and then an error code like e1 or e2 that would direct us to possible more solutions, or it might blown a thermostat more likely on a wall oven and not a range.
Jan 28, 2010 | Ovens
Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
Apr 05, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Oven shut down
IT IS THERMOSTAT IN BACK PANEL ABOUT A 48.00 PIECETWO CLIP WIRES AND TWO SCREWS IT IS NOT IN TOP OF STOVE IT IS IN FLAT ACCESS PANEL BELOW
Sep 21, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
KitchenAid KGSA906P Gas Kitchen Range Logo
146 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
