Question about Sharp 25R-S100 25" TV
Coax that cable etc. screws into is broke off...can this be replaced?
    Sergeant:
    Champion:
  • 431 Answers
Yes but have to take tuner out to replace coax conn. and may have broken traces in tuner can purhase new tuner also at tritronics
Posted on May 05, 2010
  • lhibbs Sep 19, 2010
    Help! Can I do this myself? And by "I" I mean a guy friend it someone who may be electronicly inclined unlike me :) or do I have to take it sonewhere? My tv is 46" so I hopei don't haveto move it. Again, by "i" I mean someone with bigger muscles lol. Any input us appreciated. Email to: Logan.hibbs@gmail.com
Do they make a adaptor that goes from coax to hdmi or video plugs
No - co-ax is used to carry a signal at RF level while HDMI is audio/video.
A co-ax socket can be replaced by any qualified technician
May 04, 2015 | Televison & Video
Can' hook up the cable cause internal cable broke
If the coax fitting is damaged or broke off you can with a box connect via the rear jacks---most boxes have rear av or component outputs for this.
This bypasses the coax input---just hook up and in menu select that input (they are numbered and numbers on back indicate what number each is).
Let me know if you have questions or a comment.
Mar 19, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
Satellite/Cable Coax "DTV/TV" in-port broke
Replacing connectors on televisions can be a pricy endeavor. If you can't afford to bring it into a service shop, you may have luck by switching to a different type of connector. If your Satellite or Cable receiver has an HDMI output, your best bet would be to buy an HDMI cable and hook that up instead - the quality would actually be better than coax. Failing that, depending on what kinds of outputs your sat/cable receiver has, you could also go with (in order of preference) component video (a cable with five ends, red/green/blue, plus two for audio), s-video (a round metal connector with four pins in the middle), or composite video (similar to a component video cable, but only three ends - red, white, and yellow).
Any of the above cables (including the HDMI) can usually be found at your local big box electronics retailer for under $30.
May 02, 2011 | Televison & Video
The coax cable connecter broke off how to replace it where do you get replacment connector
Google satcure website they're great at this sort of info. You can get coax plugs from people like, cpc components, maplins, rs components etc,
pete
Nov 09, 2010 | GE 27GT271 TV
The attachment point for the coax cable was pulled off-broken off
You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
Dec 03, 2009 | Sharp 27H-S60 TV
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Jun 30, 2009 | JVC AV-27220 TV
Coax cable broke off my wife tryed to put back in the cable line with coax insert broke off there was connector on the cable line she just jammed the bare cable line into the hole where the coax...
Yes there is a possibility that something shorted... remove the cable wire and unplug for 10 to 30 min and try plugging back in and restarting the set. otherwise the tuner probaly would need replaced. something any tv tech can do. AT the shop we replace these conectors al the time. just depends how bad the tuner is damaged.
Mar 17, 2009 | RCA Televison & Video
ILO 42 inch flat screen tv
can a 42 inch flat screen be replaced my son threw apple and it hit the screen
May 05, 2008 | iLO 2600 Television
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
Sharp 25R-S100 25" TV Logo
60 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
