Question about Roxio Creator 2010 Full Version for PC (244000)
Hi Name is Joe.
I had roxio creator 2010 installed once and it work just fine on this computer. I had to do a format of the hard drive, and when i put the program back in, it told me the setup has determined that your configuration does not support any of the included prodocts ... i paid 80.00 for this program and i can't use it........... can you tell me what is wrong...?
Thanks Joe
    Problem Solver:
  • 12 Answers
To create setup files (.exe), Inno Setup Compiler is the best tool. It is free to use. The 2012 version is awsome. The features are better than most commercial software. Download it here
Posted on Aug 11, 2012
    Problem Solver:
  • 17 Answers
Resolution
Installing on a Windows Vista computer
Creator 2010 requires a minimum of Windows Vista Service Pack 1 for installation. You can either perform a Windows Update (recommended) or install Service Pack 1 for Vista here.
Installing on a Windows 7 computer
The issue might be caused by the Creator 2010 setup package running in Windows Vista compatibility mode on Windows 7. Please use the following steps to turn off Vista compatibility mode for the Creator 2010 setup package:
  1. Right-click on the setup package and choose Properties.
  2. Click on the Compatibility tab in the Properties window.
  3. In the Compatibility mode section, uncheck the box that is labeled Run the program in compatibility mode for Windows Vista.
  4. Click OK to save the changes.
  5. Re-run Creator 2010 the setup package.
Posted on May 04, 2010
Recently bought & installed Roxio 2011 on Windows XP and it worked fine. Upgraded laptop to Windows 7. Roxio stopped working. Uninstalled all Roxio programs and reinstalled Roxio Creator 2011. No...
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run - type services.msc - look for all roxio service i.e roxwatch.db - double click it then select the startup type to automatic - save the changes then restart computer
Cheers . . .
Feb 02, 2011 | Roxio Creator 2011
I am receiving error code 0643 when I try to install Roxio Creator 2010 Pro and then program uninstalls.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
    • Select the Startup tab.
    • Click the Disable All button.
    • Click the Apply button, then click the OK button.
    • Click the Restart button.
    To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
  2. If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
    • Create a new folder on your Desktop.
    • Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
    • Select ALL of the files in the installer window and copy to the folder you just created.
    • To install from the folder, double click the setup.exe file.
  3. If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
    • Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
    • Go to Edit -> Select All.
    • Go to File -> Delete.
    • Reinstall your software.
Jun 11, 2010 | Roxio Easy Media Creator 10 Suite
Roxio burn exe file problem
I can't find the Roxio Burn on my computer. I keep using the shortcut on desktop, but it keeps popping up that the shortcut isn't useful if not installed. But it came installed on my computer when I bot the computer a month ago, and I have actually used it to burn a couple of cd's, but I can't locate it now. What is the problem?
May 01, 2010 | Roxio Easy CD Creator 5.3 for PC
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
My roxio creator 2010 converts tivo to dvd so slow - a 103 minute movie took 7 hours to convert and burn to disc and the picture is **** but the audio is fine. i also can't seem to trim any tivo recordings...
I like burning tivo to DVD with windows DVD maker. I use Pavtube for coverting TiVo videos . It works very well and I haven't really had any problems. Conversion speed seems fine and the videos look good. I saw Pavtube mentioned in the TiVo forums as a good way to convert for the iPad so I decided to try it. It's much better than TiVo's converter. http://www.pavtube.com/guide/copy-tivo-to-dvd.html
Mar 24, 2010 | Roxio Creator 2010 Full Version for PC...
I installed roxio creator 2010 successfully but I can't open the desktop icon.
go to my computer/program files/roxio easy creator 9 suite and copy and paste the quick launch icon and place it on your desktop
Dec 30, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
Windows 7 creator 2010 install, isthere a patch to get creator 2010 installed under windows 7 proffessional
Hello and thank you for using Fixya's services.
Roxio Creator 2010 is compatible with Windows 7 and was actually created for it. Are you experiencing problems?
Please let me know and I will be glad to help!
Nov 22, 2009 | Roxio Computers & Internet
Failure to open cd
Hi Install - CDBurnerXP Pro 3.0.116 Download from here: http://www.cdburnerxp.se/download.php Good Luck
Sep 11, 2007 | Roxio Easy CD Creator 5.3 for PC
Roxio Creator 2010 Full Version for PC (244000) Logo
220 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
