Question about RTO Golden Buzzaround Lite Scooter Meets Medicare Code * Disassembles in three
LED Flashes 5 times - Brake in freewheel or brake connection problem. How can I fix this?
  • 23 Answers
Brake in freewheel means that your scooter is not fully in gear, it must be 'set in the engaged (Fully forward) position.' See page 24 of the manual for your model, (Link below to the pdf if you need it) but if its anything like mine it just didn't click in properly. Roll it back and forward a few inches, and it should 'click' like the seat in the car when you change its position. If freewheel is not the problem (if it can't be rolled and is definately in gear) check all plugs and cords are tight in sockets, you may have a brakes problem. In this event it must be looked at by an expert. Stay safe!
http://www.rentascooter.com/downloads/_manuals/goldentechnologies/Golden%20Technologies%20Buzzaround%20Lite%20Owner%27s%20manual.pdf
Hope this helps:)
Posted on May 06, 2010
2 Suggested Answers
  • 14 Answers
SOURCE: LED Flashes 5 times - Brake in freewheel or brake
Pull the key out of the plug or key switch. There is a freewheel/brake release lever sticking out of the top or back of your scooter on the driver's right hand side. Push this handle the opposite way it is now and try the scooter. If this does not work, repeat the steps above. It is important to do this with the key out of the unit or it will not reset.
Posted on May 12, 2010
I have a Pride Sundancer that will usually go forward but not reverse. Green light flashed 3 then 5 blinks. What is the problem
Hi charge batteries & get them load tested ..U can buy a BATTERY LOAD TESTER of E/BAY cost aprox $36 this will give U an accurate reading on there condition,.3 flashe's unplug charger & turn key of & back on ..5 flashe's remove key push freewheel lever into freewheel & back into drive put key back & try it . Cheers
Nov 30, 2016 | Pride Health & Beauty
Tip
Powerchair flash codes (Applies to most powerchairs)
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace
10 and 11 are unusual and will not be seen if at all
on Mar 06, 2011 | Health & Beauty
When you put the scooter in to forwards and reverse the red light flashes 5 times then comes up error 5
hi , that is normally associate with a brake fault ? the freewheel lever ? making sure it 's in drive mode ... check all connections going to the brake from the controller.... two wires, it maybe a faulty micro-switch...
Regards
Rob
Aug 02, 2015 | Health & Beauty
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
The led flashes 9 times
9 flashes indicates a problem with the parking brakes. Check to make sure the brakes are engaged and the chair is not in freewheel. there may be a bad connection at the left and right motor connections and brake wiring. Check these connectors for separation and loose, corroded contacts. Reset the error code by turning the chair off and back on once you think you have corrected the problem. Hope this helps
Feb 25, 2014 | Pride Jazzy Select 6 Indoor Power...
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
I have an electric mobility scooter 302Le that is fully charged but will not run. The lights and horn all work but the scooter will not move. The led light in the control box flashes five times. Can you...
Barb the flashes indicate a brake problem. Make sure that you aren't in freewheel. Move the freewheel lever located at the rear of your scooter up and down a few times then put it in drive mode and turn the scooter on and see if you still get 5 flashes If so you will have to replace the brake assembly Hope this helps
Oct 20, 2010 | Health & Beauty
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Led Flashes 5 times - Brake in freewheel or brake connection problem. How can I fix this?
May 10, 2010 | RTO Golden Buzzaround Lite Scooter Meets...
Have augriga scooter no drive no free wheel flashes five times fully gharged
According to the invacare website, you have a Dynamic Rhino main control box fitted to this scooter. 5 flashes would mean a brake fault. There is usually a small switch located on the brake (which is fitted to the end of the motor). The switch is operated by a lever fitted on the brake. These are sometimes at fault and changing this switch may cure your problem. You mention that you cannot freewheel the scooter. Is there an electronic freewheel on these or a lever as mentioned above? If its a lever, and you still cannot move the scooter, the brake will have seized and will require replacement. If its electronic, the fault would almost certainly be with the wiring or freewheel switch. As with most scooter problems, they can be difficult to diagnose without seeing them, but hopefully I have pointed you in the right direction. If it came into our shop, the above mentioned is where I would start to look for the problem. Hope this helps...
Mar 12, 2010 | Invacare Pronto M51 Power Wheelchair
RTO Golden Buzzaround Lite Scooter Meets Medicare Code * Disassembles in three Logo
192 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
