Question about Bosch Axxis WFL 2060 Front Load Washer
Vibration on spin
We have Bosch HJA 8552 (fitted kichen reference). When it spins it sounds like it will shake to pieces, Have checked feet, taken top and back off but nothing obvious, Thought spring or 'dampeners' may have gone soft but cannot tell. Just over 2 y.o.
  • Bosch Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 05, 2010
Testimonial: "Thanks. Will check it out."
Have a Roper (Whirlpool) top load washer Model RAL 5144BWO, that vibrates excessively. I ran it without any clothes, and still vibrated excessively. I watched it go through the spin cycle with the lid...
Hi, Well it sounds like either one of the tension springs that hold the outer clear tub to the frame down below came off or broke, or that the basket or gearbox shaft is warped. One other thing to try is the back feet on those washers are spring loaded to take out some of the vibration, if those feet arent level it will make the washer shake. it is easy to reset those so they are level. Stand infront of the washer and grab the back of the unit and pull it towards you so that you raise the rear legs, then simply set it back down. To check the spring you will have to take the outer shell off and look at the springs that are at the bottom of the tub assembly holding the tub down on the frame. Good luck and I hope I was some help.
Dec 09, 2010 | Washing Machines
4 month old washer is so loud it sounds like someone dropping a trash can to the pavement from 5 feet high
Check to make sure it's level. Number one cause of vibration is not being level. Number two cause is soft floor and what I call "Sympathetic vibration" where the floor shakes a bit and it seems like it's in time with the vibration on the washer. It then magnifies the vibration and makes it worse.
If it's level and on a solid floor, you need to get it serviced under warrenty.
Feb 22, 2010 | GE WSXH208A Front Load Washer
Machine always shakes at spin cycle.( wash load is balanced ) it also moves, I have to sit on it to stop it from walking whe it shakes. it is maytag top load model LAT9635AAM PS - its 10 years old - if it...
try adjusting the feet, sounds like they're not all making contact evenly, vibration can cause the screw-in feet to go out of adjustment
Dec 05, 2009 | Blenders
Rocks and bounces during spin cycles
You don't state what type and model of washer you have but following is the Whirlpool service manual for top load direct drive washers.
Check the sections on the base and suspension springs and pads.
If one or more of these is not connected, or the pads are damaged, the washer will vibrate during the spin mode.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 22, 2009 | Washing Machines
Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Mar 12, 2009 | Bosch Washing Machines
Whirlpool duet sport..vibrates during spin and "walks"..on pedistal.sitting on tile
I just bought this washer and had two problems with it. 1 the vibration at medium spins and 2. a squeeking spring (every time the drum rotates a little squeek, but when spinning the squeek sounds constant.
What I discover in solving both my problems with the same solution. I had to ensure all 4 feet well on the ground and that the top of the washer was perfectly level. At one time I was out only about 2 mm on one side, but the bubble was slightly to one side on the level but still in between the level's markers. I tested with a load, and both problems were still there. Turn feet 1/2 turn on the side needing adjusting. Ran another load and you guessed it, no squeak, no vibration, spinning was quiet, I had to go over to check to see if the machine was going through the cycles. I couldn't believe that a few millimeters could make such a difference.
Now I am pleased with the performance, not to mention how clean the clothes are and the savings on water and drying.
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
529 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
