Question about Frigidaire FAC126P1 wall/window Air Conditioner
When resetting the plug for my air conditioner it clicks back off.
  • 674 Answers
Your A/C unit has a short inside or a motor locked up. If it trips immediately I would suspect a short.
Posted on May 04, 2010
  • Chris Holland Apr 11, 2015
    I have the same problem can this be a plug problem cord
My Frigidaire AC unit doesn't want to turn onafter plugging it in
Thank you for your inquiry, Eddie!
From the information you have provided your Frigidaire air conditioner is not turning on after you have plugged it in. I have identified a few possibilities of what could be causing the problem with your air conditioner to be the control panel or power cord. You may be able to perform a reset on your air conditioner by unplugging the power cord and pressing the reset button. You should hear a click and then press the test button. Once you plug it in it should start. If your air conditioner does not start I would suggest contacting the manufacturer for any additional assistance. Hopefully this information is helpful. -Matt
Feb 05, 2015 | Frigidaire Heating & Cooling
Frigidaire airconditioner compressor keeps running after turning the unit off
Thanks for the post, friend!
I understand that the compressor continues to run after your Frigidaire air conditioner has turned off. From that information it sounds like there could be a possible issue within your control panel or relay. I would recommend a reset on the appliance, to perform a reset unplug the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in. If you continue to have an issue with your compressor I would seek assistance from a professional. Hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire 18,500 BTU Window-Mounted...
Why does it starts up then shuts off and all the lights start blinking
Hey friend, I appreciate your post!
I see that your Frigidaire air conditioner will start up then shut off and blink. It could possibly an issue with control panel or the power source of the appliance. I would attempt to perform a reset on the air conditioner which would be removing the plug and pressing the "Test" button, you will hear a click and the button will pop out. Then press the "Reset" button, you will hear another click then plug the appliance in. Those are the steps to resetting your air conditioner, if that does not successfully correct the problem please reply back. I look forward to your response. -Matt
Aug 02, 2014 | Frigidaire Heating & Cooling
Where is the button to reset on a frigidaire air conditioner
Hi friend, that's a great question!
To reset your Frigidaire air conditioner you would need to make sure the appliance is turned off and unplugged. On the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in and it should be reset. -Matt
Jul 23, 2014 | Frigidaire Heating & Cooling
Why does the unit beep when I plug it in.
Good Morning Tina,
I understand that your Frigidaire air conditioner, model# FAM187S2A, beeps and flashes lights when you first plug it in. First, test the power supply cord by doing the following:
1. Plug in your air conditioner.
2. The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
3. Press the RESET button. Again you will notice a click as the button engages.
4. The power supply cord is now supplying electricity to the unit. (On some products this is also indicated by a light on the plug head)
NOTE:
• Do not use this device to turn the unit on or off.
• Always make sure the RESET button is pushed in for correct operation.
• The power supply cord must be replaced if it fails to reset when either the TEST button is pushed, or it cannot be reset. A new one can be obtained from the product manufacturer.
• If power supply cord is damaged, it CANNOT be repaired. It MUST be replaced by one obtained from the product manufacturer.
NOTE: Some plugs have buttons on the top.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire FAM187S2A Air Conditioner
Air conditioner won't reset.
If you're trying to reset it right after it trips, you're not giving it enough time for the pressures to equal out.
Also, try again, unplugging it from the wall and waiting about 20 minutes before plugging it back in.
If it got a good surge from the storm, it may have grounded out the compressor.
Jul 16, 2010 | Goldstar KG6000R Window Air Conditioner
Amcor aircon 15000btu
Have you tried pushing the reset button on the power plug? If the unit overheats the reset button will click on and the a/c will turn off. In order to turn it back on you will have to push the reset button.
Jul 09, 2010 | Amcor PLM-14000E Portable Air Conditioner
Air conditioner
The lightening may of caused a surge and your unit may have it's own protector that resets and comes back on after a time frame programed into it.
Jul 30, 2007 | Maytag M6Q10F2A Air Conditioner
Air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Jun 08, 2007 | GE AGM24DJ Electronic Room Air Conditioner
Frigidaire FAC126P1 wall/window Air Conditioner Logo
210 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
