Question about Refrigerators
Where do you add freon on the whirlpool gs6shaxmq00
  • 308 Answers
In order to add refrigerant to a refrigerator you must install valves into the suction and discharge lines. To purchase, remove, add, or in any other way work with refrigerants you need to have certification. Hope this helps.
Posted on May 07, 2010
How hard is it to add freon to a wine cooler?
Don't attempt it, need special equipment, seek additional quotes but if it's leaking them there is a gas loss issue. You should never need to add gas to a fridge that is sealed in the factory.
Askntechnician why it needs a gas top up? It must be leaking from the pipe work. Adding gas wont solve the problem, you need to find the sauce of the leak to remedy the problem longer term.
Mar 22, 2014 | Whirlpool Furniture
Compressor runs constant. whirl etomsrxtloo
Maybe low in Freon, inefficient compressor or partially restricted.
1.) Check the Freon level and add Freon if needed.,
2.) Check for leak and repair if any
3.) Change the dryer filter, pull a deep vacuum then charge the unit according to the manufacturer's recommendation. See the name plate for more info.
Note: skip all the above if compressor found inefficient.
Oct 31, 2013 | Whirlpool Refrigerators
CAN I ADD FREON TO A QHIRLPOOL WINDOW AIR CONDITIONER UNIT MODEL ACE184XS0
yes you can but you will probably have to put service ports on it as most window a/c do not come with them .The easy way to do this is to get a couple of self tap saddle valves that all you have to do is back off piercing point out of the way while you clamp the valve around refridgerant lines and tighten screws down evenly. Follow directions and make sure you use the right size spacers for the line size you have. When you have the valve properly placed and secured then screw piercing point down thru the copper and close all the way. Attach gauges to servicevalves and open valves to check freon pressure. Add freon as needed. Thank you.
Jun 01, 2011 | Whirlpool Electronic Window Air...
Coils icing
the unit either has dirty evaporator coils and this will make them ice up,or the unit is low on refrigerant/freon,try cleaning the whole unit of dirt and dust first,then you may need to install a saddle tap on the sealed system and add some refrigerant/freon as these systems seem to leak more often than other sealed systems
Feb 06, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Ice maker stopped working
It could be frozen up. Or, the control arm could be in the up/off position. Just look around and see if you have an ice buildup. Or if that wire arm is up. If there is ice just turn the temp up a notch or two for one day and your problem will be solved.
Mar 18, 2009 | Whirlpool GS6SHAXMQ Side by Side...
Can i add freon 2 my whirlpool window air condition unit myself if so how
NO........EPA VIOLATION AND YOU CAN GET IN ALOT OF TROUBLE
IF ITS NOT BLOWING COLD OR FREEZING UP TRY TO TAKE IT APART AND CLEAN IT WINDOW UNITS VERY VERY RARELY NEED FREON
Jul 22, 2008 | Whirlpool Heating & Cooling
Need to add freon
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Jul 02, 2008 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Dec 28, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Refrigerators Logo
295 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
