Immersion heater wiring
My hot water boiler is fitted with a Creda Redhead immersion heater but it is not wired in. The installation also has a thermostat in place. How shold the wiring run?
2 Suggested Answers
SOURCE:
  • 33 Answers
SOURCE: we have no heating. boiler, radiator and hot water
sounds like a pump fault get unit serviced
Posted on Jan 17, 2010
I replaced the immersion heater in my hot water tank, like for like , replicating the electrical connections as well. It does not work. There does not seem to be any power coming into the heater. The
Learn in 2 minutes to use a multimeter to measure resistence ohm and/or continuity,buy a cheap one at a local store if u don,t have and measure the integrity of the element,ceck the voltage on wiring and/plug,if no power comes in, it will not work !?!
Regards
Oct 28, 2014 | Blenders
Main fuse tripping
remove the cover from the heater spray with wd40, wipe dry, replace the cover and re-try
Dec 15, 2013 | Computers & Internet
I have the imm24 timer and would like a better quality timer which one will work
Imm24 timer is 230V 3500amp flush-mount hard-wire 24-hour mechanical-dial immersion heater timer
Following page shows imm24 timer and other brands of immersion timers
http://cpc.farnell.com/1/1/51662-immersion-heater-controller-box-imm24-apt.html
Prices are in Euros and Pounds, so I don't know distribution range of product.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Hardware & Accessories
Low pressure from immersion heater to mixer taps on bath can i fit a pump on the pipe work leading to the bath
You need to have an higher head of water on the tank that feeds the cylinder that the immersion heater is fitted to. Put the tank on a framework say 3 foot above its present level.
Regards
Alan Hood
ami-man
UK
May 10, 2010 | Plumbing
I have recently had a Howden domestic immersion
I would not have both on at the same time . We never did .
Oct 30, 2017 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Heating & Cooling Logo
638 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
