Question about Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Remote or no remote
I have a homestead product superfan model # hp4000 s/n S052068. the lights work but the fan does not does not. Checked wiring into wall swithch and celiling fan and only 2 wires are present for power. Do I need a remote or should Ibe able to work the fan from the switch. If I need a remote where can i purchase one and what would i be looking for?
bestdarngood
  • 3037 Answers
SOURCE: Fixed wooble now light does work
Well with the wire connections having been checked, the only question is whether the light worked before installation or if you tried a different light bulb while trying to get it to work. Possibly somewhere the wire is broken otherwise, good luck and please post whether the light bulb was checked, thank you
Posted on Mar 22, 2008
SOURCE: Light not working by pull chain or remote.
I would try removing the remote part. Connect the two main (light & fan) wires direct to your house main. Then if the pull chain works then you just need a new remote unit.
Posted on Apr 07, 2008
jyackle5
  • 8197 Answers
SOURCE: remote receiver faulty
That is correct you need a new receiver for the fan. The other problem that could have happened is when you replaced the batter in the remote you accidentally hit the dip switches and changed them. That is the box that has 4 white switches on it. One is in the remote and one is one the receiver that goes in the fan.
Good Luck ANd Please Rate FixYa!
Posted on Dec 29, 2008
canwoodjc
  • 3301 Answers
SOURCE: I understand that the black
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Posted on Jul 07, 2011
  • 5370 Answers
SOURCE: I have a model H52ul
First you try this connections as follows:--- L - Orange, 1 - Black, 2 - Yellow, 3 - Purple .--------Black is hot in most of the connections.But in some its not.-------- But go with this procedure.This will help.------------ 1,2 and 3 are its speeds.If you pull the chain once the speed is low, if you pull it one more time then its medium.If you pull it one more time then its full speed that is 3.---------- Connect the black wire to L. Then, you can wire Purple to 1, Yellow to 2, and Orange to 3.
If you find that the number of pulls does not match up with the proper fan speeds, you will need to move the purple, yellow, and orange leads around on the switch numbers 1, 2, and 3 until it's right.
In some switch connections it's:--- L - Orange, 1 - Black, 2 - Yellow, 3 - Purple . ---------- You try both the combinations.--------- In most of the connections black is hot, but on some connections orange is hot.-------- This will help.Thanks.Helpmech.
Posted on Jul 26, 2011
Why does do I only get one fan speed, and not three on Model 27185?
The light is only a battery indicator light. Check the capacitor in the switchcup. Small, usually black box with wires going to pull chain switch. Also, the fan has to be set on high at the pull chain for the remote to work correctly.
Aug 17, 2014 | Dryers
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Jan 28, 2012 | Hunter Ceiling Fans Individual...
We just bought a house that has 3 of the same fans. THey are hunter with remote and no pull cords. The master bedroom fan doesnt work. We tried to rewire it and the only way we could get anything to...
Hi Leanne,
Most fans have green, white, black and blue wires. Green is earth or safety ground, white is neutral, black is for the fan and blue is for the light fixture. Some fans may deviate from these commonly used colors in which case you should consult the instructions. Below are links to instructions for different Hunter remote fans, additional instructions for Hunter remote fans or you can look up your fan by model number or use. It appears that the built-in remote Hunter fans have no provision for controlling a light when the fan is wired from a traditional switch instead of using the included remote, as they have only a green, white and a single black that remains powered constantly to supply the remote receiver. The hand held remote transmitter tells the receiver to switch power to the fan motor and light bulbs as needed.
It is possible that the transmitter or receiver you're using in this room is not working. Try using one of the other remotes with the non-working fan by matching the code of the remote to the fan. If it doesn't work, try selecting a different code on the fan and match it on the remote (in case there's a problem with that particular code in this location). Try all (or as many as you care) codes to see if any codes work with this remote.
By this time, you should have either found a working code with this remote and are all done, or still have a non-working fan. Since you have tried more than one remote - and know that one of them worked in the other room, suspicion falls on a faulty fan or integrated remote receiver. You can replace the fan if you like with a traditional fan and light and purchase an after market or third party RF remote control if you no longer wish to get an integrated remote receiver.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 19, 2011 | Dryers
I have a Hampton bay fan model UC7083T It's about 2 years old and remote control stopped working. I tryed a new battery and checked the pin switches to make sure they match and Im gettig power to it. It...
mcdevito75 here, Double check your barrey install in the remote, evn new batteries could be weak, also, you may have to get to the shroud just at the ceiling, that"s the cover for the fans wireing, and see if the reciever eye for the remote is clean. Also does the remote have to be programed to operate the fan.
Jul 24, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hunter fan model 21617 remote fan won't turn on light from wall switch
You mean only the light? and the fan is working? Have you checked the light bulb? If it's ok, then checked on the wall switch. If is also ok, then probably there's is something wrong with the wiring in the fan.. It's either a bad or loose connection
Jul 01, 2010 | Hunter Ceiling Fan Light Switch Control
Heritage superfan model 4000hp fan does not work!
This fan has a unique dc motor and a proprietary controller. DO NOT USE A STANDARD CONTROLLER OR SWITCH. The controller is very rare and is no longer made or supported. The company was purchased by Casablanca Fans, but they offer no help.
May 03, 2010 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
May 25, 2009 | Hunter Ceiling Fan Remote Receiver...
Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Jan 25, 2009 | Universal Remote Control Hampton Bay...
Heritage (5BUW52WZ4HN) 52'' Ceiling Fan Logo
63 people viewed this question
Top Heritage Dryers Experts
roeb
Ottoniel
Mike
Are you a Heritage Dryer Expert? Answer questions, earn points and help others
