Question about Peg Perego 12 Volt Rechargeable Battery
We have the ride on tractor, and it recently stopped working (without any warning). It didn't appear as if the battery was draining. However, I charged the battery and reattached without any success. Is there a way to tell if it is the battery that needs to be replaced?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Check the battery with a multimeter and make sure that it is showing at least 12 volts, you can also check under the blue plastic housing of the battery and make sure that the positive and negative terminals are connected, also shake the battery and if it sounds like there is sand in the battery then its dried up and you'll need a new one, you can get one here www.powerwheelsoutlet.com
Posted on Jun 07, 2012
Ariens tractor drain the battery why?
ignition switch not cutting off all the way inside.or headlights left on or i have even seen where fuel pump not cutting off , draining battery.
Sep 22, 2013 | Ariens 34 In. Zoom Series Riding Mower
Do I need the wands for sprinkler to work?
Yes, That is how it gets propelled down the hose.
Mar 30, 2013 | Nelson Sprinkler: Traveling Tractor
Riding lawn mower stopped working, now it just makes a clicking noise when you turn the key, the grass was pretty high when this happened...did the engine blow?
the battery is just probably low,, make sure it has a full 12 volts or better, check to make sure the battery posts are clean and making good contact ,,, riding mowers charge slowly, and if the current can't charge the battery , then the mower is just draining it as you run it, hitting a large clump of grass could stall out the motor, But I doubt it Blew it up,, check those items ,, Good Luck
Jun 16, 2011 | Craftsman Garden
My JD riding mower just stopped during a recent mowing
There was a time when my JD just quit and did nothing. After doubting the battery that is what it was-the battery. Jump start your JD and if it starts up then your battery needs replaced.
Oct 20, 2009 | Garden
LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsamen 18.5 hp battery keeps draining
Either the battery is not being recharged when the engine is running or there is a current drain when stopped. If you are not knowledgeable about electrical tests you can check for current drain by disconnecting the battery negative cable when not running. If the battery stays charged then you need to find the current drain. To check for no charge when running, turn on the headlights with the key on but engine stopped. Start the engine and see if they become somewhat brighter. If brighter, the charging system works. If not, there is a problem in the charging system which needs to be confirmed with a voltmeter.
Jun 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Peg Perego 12 Volt Rechargeable Battery Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
