Question about Garmin Nuvi 660 GPS Receiver
Memory full on nuvi 660
The unit says that the memory is full and I can't seem to reset it. Any sugestions?
  • 504 Answers
Try downloading the latest version of the firmware. This can sometimes help.
Posted on Apr 03, 2008
  • Kevin Miller Apr 04, 2008
    Just because you don't like an answer, that is no reason to mark it Inappropriate. Your abuse of the rating system has been reported.
2 Suggested Answers
  • 504 Answers
SOURCE: nuvi 660
Try dowloading the latest firmware. This can sometimes help.
Garmin Nuvi 360 says memory full cant reset
Connect the unit up to a PC and try deleting some of the unused text-to- speech (TTS) voices. Keep only the ones that you need. Delete any unused photos or MP3's...and also any unused vehicle icons on the unit. When the unit is booting, it loads in all of the vehicle icons allowing you to change the selected vehicle, so this too uses up valuable memory.
Apr 08, 2013 | Garmin NUVI 360 GPS Receiver
Neither of us remember password for garmin 660 how do u reset?
You have three options for unlocking a PIN locked Garmin:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was entered
3 - Send the unit back to Garmin
Unfortunately, these are your only options as this is a security feature to prevent unauthorized use of a stolen GPS
Jan 31, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 660
Spell county? Never seen a county option on a GPS. Usually its zip or city, street, street number.
Apr 28, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
Way point memory full and will not find route
Way point memory full and will not find route Can you help? What should I do?
Mar 19, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 not working
1-Check if you have 500 waypoints, Thats the maximum.
Be sure you delete the recents search via the menu. the recent use when you did a search for a place or adress, just delete.
2- could you confirm both of you if you did not add any other maps into the units ?
3- How many MP3 you have into the GARMIN files ?
Need this to answer your question properly ?
It should not happen if you did not overload the unit 660.
Everything has a maximum who is published by the manufacturer.
Best regards
Dec 26, 2007 | Garmin Nuvi 660 GPS Receiver
Memory full is being displayed when i try to go to a new destination and when i try to delete a favourite the unit turns off.
Garmin nuvi 610 T
memory full was being displayed on screen whilst on destination ,sometimes followed by route waypoint memory full .
I found by turning unit off , then holding finger on top left of screen ,and at the same time turning back on again the unit would go into maintenance mode.
Follow prompts on screen to reset waypoint memory.
Mine works as good as gold now,hope this helps!
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Memory full
Have you tried downloading the latest firmware? Sometimes this can help.
Oct 29, 2007 | Garmin Nuvi 660 GPS Receiver
Says memory full and will not work
Hi dogman33, This is a common problem with the nuvi 660s with older firmware. Garmin's solution is to perform a "hard reset" and to upgrade the device firmware. Upgrading firmware is an easy procedure, just visit Garmin's website (www.garmin.com) and download the software called WebUpdater. Run that and follow its directions. Here is how you can perform a hard reset to clear all your waypoint memory: MAINTENANCE MODE: Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer. Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?" Step 3. Select the yes button. Step 4. Enter your PIN if enabled. Step 5. Main Maintenance Mode screen should have 4 selections: System information View Diagnostics Clear User data Clear Waypoints Step 6. Choose "Clear Waypoints". After some time the unit should reboot. Hope this is helpful! spydee
Jul 25, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
157 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
