Question about Hotpoint Aquarius WMA56 Front Load Washer
Is there a filter on a wma56 washing machine, if so where is it
  • Hotpoint Master
  • 3,463 Answers
The filter is located at the rear of the washer, to gain access to it, remove the lower rear panel of washer.
Remove large black hose from bottom of drum, and remove and clean plastic filter inside the hose.
Refit filter and hose, and test .
Posted on May 04, 2010
Testimonial: "Excellent help, what does the ball do? Many thanks"
  • vasco-L May 12, 2011
    husband found and cleaned the filter, thank you very much!! Mrs S Lewis
Hotpoint aquarius 1300 wma56 not draining. I've taken out the filter and cleaned. Put all back together, did spin cycle - all good. ran a full wash. Now stuck with water in not draining or spinning.
The motor is not reversing direction when it is supposed to pump out the water from the machine. The timer may be the problem or the motor itself.
Apr 26, 2016 | Hotpoint Washing Machines
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
How to a change filter on my hotpoint aquiares washing machine
Its located within the sump hose in the middle bottom of machine. It unclips to remove exposing filter.....
Mar 19, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Dont know where the filter is on an htpoint aquaris wma56?
if its similar to the WMA58 the filter is within the pump houseung one has to take the pump out disconect the tubes and you should see the filter in the center of the housing above the pump
Feb 16, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Where do ilocate the filter on a hotpoint wma 13 washing machine
You will find the filter inside the large black sump hose fastened to the bottom of the tub..
Remove the lower panel at rear of washer, locate hose and remove same ,remove and clean filter inside hose
Refit filter and hose and test.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius wma56
probably due to not draining.
there is a filter in the system which you need to remove and clean. possible also that you have a foreign object jamming the pump.
take the back panel at the bottom of the machine off.
you will see a large diameter hose going from the bottom of the tub to the pump.remove this hose at the tub end. lots of water will come out so make sure none goes on the motor. the filter is inside this hose. take out and clean
let me know if this doesn't work
Jul 05, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine error 14
check for blocked sump hose filter, this should resolve problem
Oct 15, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
590 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
