Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Hi how can i change the oil in the mechine by my self
    President:
  • 180 Answers
Press the main menu key,then press upper arrow till screen display "Change vacuum oil".once screen display change vacuum oil then press "Yes" key & now carefully follow the on screen text.
NOTE:DO NOT OVER FILL THE VACUUM PUMP(maximum oil level for vacuum pump middle of sight glass).
Hope this will help you to change the vacuum pump oil.
Posted on May 04, 2010
Hi my mother in law have a frister & rossmann 202 sawing mechine fault. The needle mechansm will only go down half way , it seems like either something is jammed or seized any ideas ? Tom
If it hasn't been cleaned and thoroughly oiled in a long time, it probably has seized due to the old oil drying out and sticking the moving parts together. If this is the case, the following should have it working:
Wheel on right side that controls the needle up and down is very tight...
Jul 23, 2017 | Sewing Machines
I have an old jeneme sewing mechine can I exchange it
sure you can trade it in but you would be better off selling your self the dealer may give 200.00 for it if you buy a new one from him
Oct 11, 2014 | Janome Memory Craft 9000 Computerized...
How i have to put the piston lube in titan impact 400?
There is a small opening on the front of the mechine has a little lip put 5 or 6 drops in.
Titan mechines don't have poly and leather packings its plastic and reopream O rings so it dosn't need as much throught oil as say a Graco mechine .
But I do like to run a little marvails mistery oil through after cleaning the mechine espeiclly if you are going to store for a while .
You see I use my mechines all of the time .And the biggest problem is people don't clean them correctly .It takes 1/2 an hour to clean any spray pump up and thats with latex oil paint take much longer .
Never under estmaite thats good enough because its not .
May 18, 2014 | Titan Spraytech Piston Lube Piston...
I have a North Star pressure washer GC160. What oil do I use in pump and what is recomended for the Honda engine? Can you also tell me where I can download a manual? Bob
As far as the pump gose just use a 30 weight oil they call it pump oil but realy its a 30 weight oil if you want the # its AW-4085-0016 or equivlant . The engine oil is a 10 -30 in most tempatures they say use a 30 wight above 40 degrees but i use mobil one extend proformance 10 -30 all year long in all of my mechines and have never had any problems and there all honda engines . Just change the oil every year some of mind are 35 years oil and run perfictly
May 09, 2011 | Northstar Pressure Washer 2800 PSI
Does the 1994 Ford escort use a hydraulic clutch?
No your escort has a clutch cable, it is on the year change point between shapes but if it is the older shape then you have what is called a ratchet and pawl mechinism for self adjustment of the cable, these are however prone to failure and not the easiest job to change. If you have a later shape escort then your clutch cable is adjust by means of a 6mm allen head type screw on the clutch pedal.
Hope this helps
John
Dec 23, 2010 | 1994 Ford Escort
The cooling function is always on. The dryer will not heat regardless of the mode that it is in Normal/Timed/Manual
hi your mechine will be having a option called reset button by reseting it your mechine program ill be reset and come s to normal state
Aug 24, 2009 | LG Dryers
Pauoni hotlem coffe mechine user manuel
Check out this manual it is not a pavoni but the same concept. groups.google.com/group/espresso_worlds/files
Jun 28, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Hello sir, here we are having a canon ir 400 xerox with printerboard. Now we are facing a problem with it. that is, it self it is printing 3 papers when we switched on the mechine. ( also printing when...
Best I can determine is that the print board may need rebuilt. This is an older model and the print board on these all need rebuilt once at least. Nation-wide repair service can help you. You can remove the board and send it to them. they will repair for about 375.00 1 800- 798-1814 www.nwrsinc.com
Jan 05, 2009 | Canon imageRUNNER 400S Copier
My self cleaning oven will not unlock
i would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
May 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
184 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
