Question about Nintendo Wii Console
How can i eject the CD manually ? - Nintendo Wii Console
    Scholar:
  • 142 Answers
Hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Posted on Oct 02, 2010
  • 57 Answers
Press the eject button on the Wii.
The eject button is a rectangle with a triangle on top of it. It is located near the bottom of the front of the Wii. It should be just above the gray box holding the Wii if the Wii is vertical.
If the Wii is horizontal, the eject button should be near the top left corner of the Wii.
Posted on May 04, 2010
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
look near the disk tray for a little tiny pin whole and take a paper clip and bend it straight now poke it into that whole until it open this is the manual way of ejecting disks if all else fails
Sep 23, 2010 | Tascam CC-222MKII CD-RW Cassette Combo "...
Its the drive that u slide the cd in
In the front of the CD Drive, there is small pin hole, it is usually located near the Eject button. To manually eject it, use a pin about 1 to 2 inches long, push it in the pin hole until the tray ejects.
Jun 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
1995 Explorer 6 cd changer - how to manually eject cartridge
No there is none you have to hook up power to it then press eject.
Jun 27, 2009 | Panasonic CQ-DPX33 CD Changer
CD won't eject
If it brand new take it back to were it ws purchased to have it replaced.
Nov 12, 2008 | Kenwood KDC-MP4028 CD Player
Cd rom will not eject
On the eject tray of the cd/dvd drive you will see a small pinhole use a pin and insert into that, the cd drive would eject, ITS A MANUAL EMERGENCY EXIT BUTTON ON ALL CD/DVD DRIVES, INCASE THE CD DRIVE DOESNT EJECT normally as your case here
Aug 27, 2008 | Dell Dimension C521 PC Desktop
CD player won't eject CD and does not recognize the CD
You will have to remove the player from your Sierra and disassemble it sufficiently to remove the stuck CD.
May 30, 2017 | Car Audio & Video
Cd wont eject.
I was having the same issue with my KD-S5050. I also tried the CD eject lock reset with no results. By using the following steps I was able to reset my CD player and it is working properly again. On page two of the user manual is shows how to do a full reset of the cd receiver. While holding SEL (Select), press ATT (Standby/On Attenuator) for more than 2 seconds. This will reset the built-in microcomputer. http://www.fixya.com/Brands/J/JVC/Manuals/kd_s5050_cd_d2ce2654fa2aab37f3ad2b4ce1e33443/images/KD_S5050_CD_D2CE2654FA2AAB37F3AD2B4CE1E33443_2_p2.jpg NOTES: ? Your preset adjustments ? such as preset channels or sound adjustments ? will also be erased. ? If a CD is in the unit, it will eject when you reset the unit. Be careful not to drop the CD.
Oct 31, 2006 | JVC KD-S5050 CD Player
Nintendo Wii Console Logo
130 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
