Question about Delta & Single Handle Shower Faucet
I WANT TO REPLACE TUB FAUCET. IT IS SINGLE HANDLE-OLDER DELTA
  • 349 Answers
It should be compable with a new delta if you replace it with one or you can get washers to rebuild it yourself. Delta are a real good faucet.
Posted on May 05, 2010
4 Suggested Answers
  • 101 Answers
SOURCE: Tub faucet
You will need to turn of the water and remove the handle, then remove the large brass or chrome ring behind the center sleave that is behind the handle. now that ring is what holds the cartridge in the valve body, you will need to remove the cartridge the rubber seats and springs will both need to be changed ,you can buy a rebuild kit for this facuet, it has everything you need even the o rings you will find in there . Hope Ive Solved your problem! Thanks
Posted on Dec 16, 2008
  • 760 Answers
SOURCE: How do you remove the handle from a classic delta
On most delta models you pop the cap in the center of the handle. Then there is a screw to remove the handle. If it is old the bonnet can be hard to remove. Be careful, as you don't want to damate the complete faucet behind the wall.
Posted on Jul 19, 2010
  • 67 Answers
SOURCE: how do i install a new cartdridge for a delta
Remove the shower control handle. If the cartridge is threaded there will be a nut on the top. Remove with a crescent wrench. If there is no nut then there will be a retaining clip and the cartridge will then pull straight out. Installation is the reverse procedure.
The faucet drips constantly from a single handle tub. How do I fix this?
we would need a little more information but sounds like it will need replacement, The water will eat up the meatle and make a rebuild impossible sorry but no quick fix the hot water lineis usley the culprit
Aug 09, 2017 | Plumbing
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
How do you remove the handle from a classic delta single handle tub faucet? I don't see a way to take off the handle itself to replace the cartridge.
Jul 18, 2010 | Delta & Single Handle Shower Faucet
How do i install a new cartdridge for a delta single handle faucet in my tub
May 31, 2010 | Delta & Single Handle Shower Faucet
How do I repair a leaky Moen faucet handle. When I
It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
Jan 13, 2010 | Moen & One Handle Tub & Shower Faucet
I have an older delta faucet. Sprayer does not work well.
i believe the faucet shaft,..they usually are on delta models i've worked on,........your best to get a full rebuild kit for this and do the whole thing when you've got it down,.....good luck, cracklin joe
Jan 10, 2010 | Delta Faucet #RP320 Divert Assembly
Bath tub water faucet leaks. It is a single handle type.
You will have to replace spring ang washers behinde valve cartridge.
Oct 24, 2009 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
242 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
