Question about Advent Netbook
AMD n15235 Motherboad. Computer will switch on but no output to monitor. I have cross checked monitor and cables but no use.
  • Advent Master
  • 2,404 Answers
Try unseating and reseating each memory stick one at a time in each slot one at a time. Try turning on the laptop after each reseat to see if you get video.
If that doesn't work then make sure only the AC Adapter is hooked up with the battery taken out.
If that doesn't work then take out the hard drive and dvd-drive. If you still can't get video then the motherboard is bad.
Posted on May 04, 2010
Pinkish tint on left side of screen?
If another monitor works fine then the screen is fubar and needs replacement.
Feb 21, 2016 | ASUS F1A75-V EVO AMD A Series Motherboard...
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Supported mother bord for AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+ 3.5MB HD8450WCJ3BGH
Just what is the problem? From what you wrote I gather you are seeking a Motherboad? Or what?
Jan 09, 2014 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
My laptop screen got wet now it has a dul screen and a dark area
I always start with seeing if when connecting an external monitor to the Laptops VGA output is the same or different to what you see when just via the Laptops screen. Reason is so that can narrow down to JUST Laptop screen or graphics chip, maybe even OR connection at cable either end, Motherboad or Screen.
Is the Laptop turning on alright i.e. no frying, I assume it has dried out from when it got wet. localised to screen only or possibly inside of Laptop....Lights up with power, fan spins hard drive spins, right? If so try an external monitor.
Feb 20, 2013 | Proview PL913S 19" Flat Panel LCD Monitor
The lead from the pc to the screen is brocken so the screan doesn't come on when the pc is switched on
If the screen connected to this computer has a detachable video cable (as almost all modern monitors do) then detach the video cable at both ends throw it away and replace it with a new one. Video cables are not expensive.
If yours is an old monitor with a permanently attached cable then this might be the perfect opportunity to upgrade to a new modern monitor which will come with a new cable enclosed. The latest flat screen PC monitors are relatively inexpensive.
Aug 30, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
My monitor says "no input signal" every time I put it on. I have checked all the wires and connections and they seem fine. Any suggestions?
Starting from the monitor and going to the video connection to your computer, make sure everything is connected and undamaged. If your video card has more than one output, try switching the cable to the other output. If neither is working, and the monitor works fine from a different computer, then its the video card, otherwise its the monitor. But again, before dropping any money on a new monitor, try a different cable, and try switching the cable to the second output if there is one. A video card is definitely cheaper than a monitor.
Aug 22, 2010 | HP Computers & Internet
Where to free download matherboard winfast n15235 driver
Here is a link:
http://www.foxconnchannel.com/support/downloads.aspx
The problem is that the N15235 is not the model of this motherboard. It turned out to be the Foxconn 6100M2MA-RSH2.
Kind regards and please post if you need further assistance
Feb 26, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Acer desktop with no monitor output.
Ensure the monitor is on. If so, can you see ANYTHING while the computer is booting up? Even the first BIOS screen?
Aug 23, 2009 | Computers & Internet
Connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Nov 15, 2007 | Acer AL2017 20" LCD Monitor
Advent Netbook Logo
88 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
