Question about IBM Wheelwriter 30 Typewriter
New ribbon - not typing - IBM Wheelwriter 30 Typewriter
  • IBM Master
  • 3,594 Answers
The print solenoid cap is probably broken. We sell them for 20.00 including installation inst. and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Posted on May 13, 2010
Ribbon will not advance
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
unaasp192
Feb 17, 2010 | Royal Office Equipment & Supplies
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
New ribbon and can't get it to type
did you make sure that the end pieces are engaged into the brackets in the part facing you. Also if the correction tape is not loaded onto the ribbon prior to installing it, it will do that too.
Hope this helps, Denise
Aug 19, 2009 | IBM Office Equipment & Supplies
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a
Try typing on a mulipart form. If it types on the copies and not the orinonal the ribbon is the problem. If it dosen't type on the copies then the plastic cap on the print solenoid is broken.
We sell the cap with installation instructions for 20.00 includes shipping.
DickyO
216-241-0027
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
My printer displays ribbon error. but there is ribbon inside
you can change which ribbon type is installed in the printing preferences of the printer driver.
make sure you have the right ribbon type selected.
CYMTKO vs. CYMTO, etc.
There is also a button that will auto detect the ribbon right underneath the pulldown menu.
May 26, 2009 | Fargo DTC550 Thermal Card Printer
Evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
Beeping sound when powering unit on
Have you simply pushed the carriage back to the middle? If it is like the ML100 (it looks the same) you can just push it over ...with the pwoer off. Then put in you new ribbon. And this time, when you turn it on, it is the new ribbon that hits a switch on the underside of the keyboard, located to the upper left. If you do not have a ribbon installed, it will travel all the way to the left, and beep, beep, beep, beep. ,,,, The switch is hit with the ribbon housing.
Jun 25, 2008 | Brother ML-300 Typewriter
Ink ribbon
Bad ribbon or ribbon drive gear or ribbon motor.Lawrence
Mar 07, 2008 | Brother SX-4000 Typewriter
Ribbon problem
does the ribbon feed by hand? If not get a new ribbon.
DickyO
Dec 24, 2007 | Brother ML-100 Typewriter
IBM Wheelwriter 30 Typewriter Logo
55 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
