Hi. I have a DVDRHD400F and I cannot record a programme stored on the hard drive to a DVD. Can you assist as the manual is not very helpful. Regards Gwen
    Brigadier General:
  • 6,966 Answers
Hi Nuffwerewolf,
I am assuming that you are referring to "...program stored on the hard drive..." as movie files and you would want to be recorded on a DVD.
Insert a blank compatible DVD disc, go to the HDD menu, press on "Add/Clear", it will now allow you to add/remove program to the Dub List. The display would be a percentage bar in the top right. Press on "Record/Dub" and it will burn the DVD (burn speed is 4x).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 26, 2008
    Genius:
  • 1,913 Answers
Hi
check that your files type .it must be dvd plasyer supporting file like avi,mp3 or etc.
i think your player not support your files so convert it to your dvd supporting file.
My logik L160STB11 freeview tv recorder won't record properly
mine did that then wouldn't recognise the hard-drive
Apr 25, 2012 | Televison & Video
DVDRHD400F tuner has no sound.
First of all check all your audio connections make sure the output o of the receiver goes to the input of your tv.
Keep me posted.
Thanks,
Lee
Jul 19, 2008 | Wharfedale DVD-M3 DVD Player
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
Jun 01, 2009 | Televison & Video
Cannot get DVD recorder DVD 3470H to download from hard drive to a disc. The machine is about a year old and I'm using recordable DVD-R When I try to record onto the disc I get a screen which says the...
Hi Guys,
Thanks for the response.
I've solved the problem.
I was trying to download a programme that was too big from the hard drive to the disc.Once I inserted a divide in the progeamme everything worked Ok,
Cheers,
Dec 16, 2008 | Televison & Video
Philips DVDR3450H Recorder does not record all of timed programs
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Jan 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Error code
I had the same problem - turn off at the wall and on again fixed it.
Dec 07, 2007 | Wharfedale DVD-M3 DVD Player
Programmed recording to the hard drive
Either You haven't set the time/timer correctly or you need to find a way to clear/format the hard disk.
Aug 16, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Dvd recorder
sounds like the video codec got scrambled. if you are running windows, then try using restore [start-programs-accessories-system tools-restore]. if you never turned restore feature on, then re-install the DVD software
Jun 03, 2007 | Lite On LVW-5045 DVD Recorder
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
