Question about Pioneer DEH-P6800MP CD Player
I am getting an engine sound when in use with amp
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
You may have a bad ground to the rca's, try running a wire from ground to the rca shield. if it is a bad ground to the rcas, the noise should go away.if you are good at soldering, should be able to just solder a wire to the rca shield.
Posted on May 04, 2010
Getting humming sound from amp, replaced rca cables, made sure the ground was clean, tried friends amp also. Pioneer 700bt. Any suggestions?
Check the ground on the battery and the engine for proper conection. Cheap brand stereo also causes engine noise
Jun 04, 2015 | Pioneer Car Audio & Video
I have a yamaha THR 10 guitar amp and I am using the 8 alkaline batteries to power it instead of pluging it in to the power inverter of my truck. I am a truck driver and got this amp because I want to play...
If it was electrical noise you could get a suppressor just like you would for a car engine. But it sounds to me that you are saying it's amplifying the actual sound of the engine. If this is the case there's not a lot you can do. As the amp is designed to amplify the noise of a guitar, which is noise in general, not an electrical signal. At least that's how understand how guitar amps work. Though I will stand corrected if I am wrong!
May 27, 2017 | Yamaha Audio Players & Recorders
Can a torn tailpipe cause engine noise
End ---as in outlet,no way
But you should get invloved & get under it
& try & find the problem
Jun 22, 2012 | 2007 Infiniti M35x
While start the engine its too noisy the engine after 10 second the sound back to normal why
Low oil pressure until it gets pumped around the engine on startup & .maybe have the oil changed & filter replaced...
May 16, 2011 | 2005 Ford Expedition
HELP: Now & then I experience a sudden jolt of power in third gear. Its usually just after I've changed up a gear & have twisted the throttle - then a few moments later it hits a 'flat spot' that...
I have the same Problem, I have just striped the hole engine and re built it, thought a small end had let go, but Im getting the same as you, Any Idea what it is yet as I am very interested in knowing too.
Oct 07, 2010 | 1998 Suzuki GSF 600 S Bandit
I have a 1994 Subaru Legacy and It has started making a "knocking sound". Cked the oil, it was OK
knocks when cold ( Start ), then sort of diminish or disappears when warming up ???
Knocking goes faster when accelerating when cold ???
If Yes, then Piston knocking on the wall of the cylinder . The sound disappears as the engine is getting warmer it dilates and the gap gets smaller.
If this just started,
1. Put quality oil & filter ( Mobile Full Synthetic Oil & Mobile Oil Filter or Purolator )
2. Do not put cleaning agents mixed with oil.
3. Personaly i've put "Restore" Engine Restorer & Lubricant in cars with more then 200 000 km and the results are amazing. But only "Restore". My Volvo is at close to 300 000 km, and it runs great. It's not a cleaning agent.
By experience if the knocking just started you can put an easy extra 100 000 km on the engine before a rebuilt. Quality Oil & let the engine warm up ( 3 mins ).
Nov 02, 2009 | 1997 Subaru Legacy
Knocking sounds in park and neutral
sounds like transmission internals have failed
best to get overhauled or replaced as change over which could be cheaper and quicker.
Jul 20, 2009 | 1997 Buick LeSabre
Hissing sound from engine & check engine light on
sounds like an intake manifold gasket leak.
Jul 11, 2009 | 2004 Suzuki Forenza
Speakers dropping out & engine sounds
sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Sep 03, 2007 | Pioneer DEH-P690UB CD Player
Pioneer DEH-P6800MP CD Player Logo
85 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
