Car Audio & Video Logo
Anonymous Posted on Mar 26, 2008
Digital audio dhc 2754
I have a dhc2754 digital audio high current amplifier is it rated at 1000 watts rms and is it enough power for 2 kicker 15 inch L7 subs
brandon day
Level 2:
Scholar:
  • Expert 173 Answers
  • Posted on Apr 03, 2010
brandon day
Expert
Level 2:
Scholar:
Answers
173
Questions
6
Helped
70703
Points
251
No thay need 1000 rms each i would go with a hifonics bxi2010d amp from vminnovations.com for around $300
Can i run my kicker1000.1zx to thisntx7912 sub
Yes, you can run a Kicker 1000.1ZX amplifier to power the NTX7912 subwoofer. The Kicker 1000.1ZX amplifier is a monoblock amplifier capable of delivering 1000 watts RMS power at a 2-ohm impedance. The NTX7912 subwoofer is a 12-inch subwoofer rated for handling up to 750 watts RMS power.
Since the Kicker amplifier can provide more power than the subwoofer's RMS rating, you will have sufficient power to drive the subwoofer. However, it's essential to set the gain properly on the amplifier to prevent overpowering and potentially damaging the subwoofer.
I have 3 L7 kicker 15" subs will my audio pipe 1500 watt run them
Well the L7 15'' solo-baric subs are rated at 1000 watts RMS, so that would be 3000 watts of RMS amplifier power you would need to supply to adequately power all of them. I also suggest that an amp capable of producing more power than what is needed is usually better in order to prevent the amplifier from running at maximum capacity for long periods. In short your amplifier will power those subs, however you will only be able to supply 1500 RMS watts to the three subs so you will only be pushing the subs to 50% of their rated capacity while using 100% of amp capacity which will make your amp run "hot" and your subs run "weak", but if you're in a pinch it will work. Your best bet in this situation is to wire the setup so that the subs and amp are operating at minimum ohm stable impendence (usually 2 ohm). Seeing that you have 3 subs begging for 3,000 watts of power and you are only going to give it half of what it wants, I would suggest upgrading the amp or at least buying another one so that you can bridge the wattage and redistribute to all three subs with the correct impendence.
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Two questions. 1) can my amplifier over-power this sub; kicker L7 15 inch dual voice coil 1,000 watts RMS wired for 2 ohms? 2) is my amp too small for this sub-woofer? thank you for your time.
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
2helpful
3answers
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Will it push 2 alphine type rs
no it could one 12 but no 2 and def not a 15 when mach speakers to a amp you want to mach up the rms power you want to amp to put out enough to power bolth speakers so like 2 500 watt rms you would want a 1000 watt rms amp
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
4helpful
What amp will push 2 kicker 15inch cvr's
Hello herb31,
Kicker lists the RMS power handling range of the CVR's from 100-500 watts, with a peak power capability of 1000 watts. There are lots of monoblock amps within that range. It just depends on how loud you want them and how much you want to spend.
In the low range, an amp like the Alpine MRP-M500 will deliver 250 watts to each sub at 2 ohms. And it only costs $179. Currently, the MRP-M500 is out of stock at Crutchfield. I just bought the last one. So my 2nd recommendation would be the Sony XM-1S, which has the same power rating and according to Crutchfield is no slouch either. It's also $179. I really like the Sony, too. It has a small footprint that makes it easy to find a convenient mounting location. Both the Sony and the Alpine are CEA-2006 compliant, so you can be sure that the manufacturer provided specifications are not overrated. Assuming that your vehicle electrical system can deliver the current, both the Sony and the Alpine will deliver an honest 250 watts RMS to each of your Kickers. And 250 watts will make them kick pretty darned good.
In the medium power range, consider either the JL Audio G Series G1700 which delivers 700 watts into 2 ohms. It costs $419 at Crutchfield. Or perhaps the Kicker 08ZX750 with 750 watts at a cost of $399.
To push the CVR's really hard, close to their 500 watt RMS maximum power range, look for an amp that delivers 1000 watts. In this range, you will definitely some heavy-duty wiring, electrical system upgrades, perhaps a 2 farad capacitor, and be ready to spend at least $600 on the amp. Your best combination of power and price would be another Alpine, the PDX-1.1000M, at $799. If you buy one from Crutchfield, they will throw in a 4-gauge amp wiring kit. And if you use a "friend referral code", such as mine, which is p7sdj-hrx8q-9800g, and your order is at least $200, you'll get another $20 discount. And I get a $20 credit toward a future order.
Hope this helps. If it does, please rate as "FixYa".
2helpful
2answers
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Top Digital Audio Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
