Question about Sylvania LC320SL8 Television
4a/125v fuse blows every time I plug the TV in.
  • 122 Answers
The smps needs repair.the primary circuit is shorted.stop the game with the fuses and contact the service! dont mess with the board of the smps. the voltage there is at least 200v dc and the current is strong enough to kill somebody!
Posted on May 05, 2010
Keeps blowing the 4a 125v fuse inside when I turn the power on
then there is a fault with the power supply in the tv
Mar 27, 2011 | Sanyo Televison & Video
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
It keeps blowing the 4A-125V fuse every time I plug it in...
There is something shorted in the system. often it is the audio output which fails especially if it is run at high volume levels. Unless you are trained in electronics, I suggest you find a repair shop that repairs audio equipment. (Sorry) Hope this helps
Jan 03, 2011 | JVC MX-D602T Shelf System
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
Sylvania edtv ld200sl8
will not power. the fuse 4a 125v blows immediately when plugged in.
Sep 04, 2008 | Sylvania Televison & Video
Sanyo 25" TV struck by lightning - where do I begin?
Not to different from arcade, If the fuse is blowing right away check the bridge rectifiers next for shorts and anything on the primary ac to dc side first, Caps,may have a surge suppressor on the ac side. If it was lightning sure you will find it in this area. Secondary supply shorts usualy do not blow fuses, Just cause the supply to shutdown.
Jul 10, 2008 | Sanyo DS32224 TV
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Sanyo tv blows fuse when you turn it on
u have a short in the power supply section
Oct 24, 2007 | RCA F27242GY 27" TV
The tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Aug 14, 2007 | Sylvania 6432GG 32" TV
Sylvania LC320SL8 Television Logo
479 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
