Question about Motorola Mobility Q
Minitor V Battery Removal...how release battery from pager? I've slid the lower lock, but not sure how to work the tab at the top of the battery/pager. Afraid of breaking it if I work it wrong.
  • wb2002500 May 04, 2010
    Thanks...when you say the hinged door, is that the small tab on the top, under the belt clip? If so, I understand battery removal as:
    Looking at back of pager, knobs up:
    1. Remove belt clip
    2. Slide battery lock (small slide at the lower right of pager) to the right
    3. Pry hinged door (small tab engaged on top of battery) open.
    4. Slide battery out.
    I just can't tell if that little tab on top is hinged...was going to try to pry but was afraid of snapping something off.
    Thanks for the help!
    Thanks...did the trick!
  • 713 Answers
Hi,when you Swing open the hinged door, lift out the battery by prying up the left edge and gently detaching it,its really tight just stick something like a flat screwdriver under one of the sides carefully and lift up a little.problem solved
Thanks and take care
Posted on May 04, 2010
  • Oyelade Gbenga May 04, 2010
    Hi,the tab is just tight,you don't have to be scared,you won't damage anything,just pry the tab open and the battery is out,simple.
,how can I remove stuck Nikon coolpixx p5200 digital camera battery
You can easily tell if the battery is upside down. There will be three brass colored contacts on the top if it is upside down. There is a yellow tab lock that holds the battery in. You must slide that tab away from the battery and a spring should pop the battery out. If the battery is not upside down, but is reversed left and right it does have a tiny bit of a wedge shape but nothing that should bind the battery to the point of damage. If the battery does not pop up after the tab is slid away (you must hold it in this position until the battery rises), try keeping the tab to the left and pressing the battery down a little, then releasing it to see if the spring will eject it. Last resort, hold the tab out of the way, press a piece of real strong adhesive tape, such as a very good duct tape on to the end of the battery and pull. I hope one of these suggestions help. Be sure to read your manual prior to using the camera again.
Oct 18, 2014 | Nikon COOLPIX P520 Digital Camera Red...
How do I replace turn signal switch
Multi-Function Switch Removal
  1. Disconnect the battery ground cable.
  2. A Remove the ignition switch lock cylinder. B Insert the ignition key into the ignition switch lock cylinder and turn to RUN position. C Push the ignition switch lock cylinder release tab with a punch while pulling out the ignition switch lock cylinder.
  3. If equipped, twist the tilt wheel handle and shank counterclockwise and remove.
  4. A Remove the upper and lower steering column shrouds. B Remove the screws. C Remove the upper and lower steering column shrouds.
  5. A Remove the multi-function switch. B Remove the screws. C Disconnect the electrical connectors. D Remove the multi-function switch.
Re Install:
  1. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 10 mi or more to relearn the strategy.
  2. To install, reverse the removal procedure.
#2 Illustration
#3 Illustration
#4 Illustration
#5 Illustration
Re-install
Sep 22, 2014 | 1998 Ford Explorer
How can i spray cleaner into the Vol control on sport 10X
Not a good idea. The best option is canned air. To remove the case you will need a frame removal tool. Remove the battery tray from the radio (carefully, so as not to damage the drop-in charge capability), look inside the case and you will see two channels (like gutters in a bowling alley) along the inside sides of the lower portion of the radio. Slip the frame removal tool into these channels and slide it up until it reaches the little plastic ears (tabes) about midway up the case. Push up on the tool, this will release the ears (tabs), then the component board of the radio can be slid out the top of the housing. Be very careful, so you do not scrape components off the component board.
Your volume potentiometer is a common failure part on the radio. If air cleaning does not solve your problem it needs replaced. Parts for this model are in short supply, check with your local dealer if you need a new volume pot.
Feb 28, 2014 | Motorola Radio Communications
How to replace a power steering pump on a 1998 dodge caravan
Hi there:
Check this REMOVAL & INSTALLATION procedure...
CAUTIONThe Supplemental Inflatable Restraint (SIR) system must be disarmed before working around the air bag or SIR wiring. Failure to do so may cause accidental deployment of the air bag, resulting in unnecessary SIR system repairs and/or personal injury.
  1. Disconnect and isolate the negative battery cable from the battery.
  2. In order to disarm the air bag system, allow the SIR system capacitor to discharge for at least 2 minutes, before performing any removal procedures.
  3. Remove the screws that secure the parking brake release handle to the instrument panel.
  4. Remove the screws that secure the bottom of the lower steering column cover to the instrument panel.
  5. Disengage the retaining clip that holds the right side of the lower steering column cover to the instrument panel.
  6. Remove the lower steering column cover from the vehicle.
  7. Remove the mounting screws that hold the upper and lower steering column shrouds and remove the lower steering column shroud.
  8. Install the ignition key and turn the key cylinder to the RUN position. This is important because it will not only aid in removal of the ignition lock, but will also place the socket (in the lock cylinder housing) in proper alignment for the installation of the replacement ignition lock.
  9. Press in the lock cylinder retaining tab and remove the key cylinder (ignition lock).
To install:
  1. Install the ignition key into the replacement ignition lock key cylinder. Turn the key to the RUN position. Depress the ignition lock key cylinder retaining tab.
  2. Align the shaft at the end of the ignition lock cylinder with the socket in the end of the ignition lock cylinder housing.
  1. Align the ignition lock cylinder with the grooves in the lock cylinder housing. Push the ignition lock cylinder into the housing until the retaining tab sticks through the opening in the lock cylinder housing.
  2. Turn the ignition key to the OFF position and remove the key.
  3. Install the lower steering column shroud and install the mounting screws.
  4. Place the lower steering column cover into correct position on the lower instrument panel and engage the clip that secures the right side of the cover to the instrument panel.
  5. Install the lower steering column mounting screws.
  6. Install the mounting screws that hold the parking brake release handle to the instrument panel.
  7. Reconnect the negative battery cable.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 10, 2012 | Cars & Trucks
How do I replace the turn signal multi-function switch in my 1998 Ford Expedition
SECTION 211-05: Steering Column Switches 1998 Expedition/Navigator Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/11/2000 Multifunction Switch Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the ignition switch lock cylinder (11582).
    1. Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
    1. Insert a punch through the hole in the lower steering column shroud and push the ignition switch lock cylinder release tab while pulling out the ignition switch lock cylinder.
  1. Twist the tilt wheel handle and shank (3F609) and remove.
  1. NOTE: Move gear selector to lowest position to access steering column opening cover.
    Release the four clips and remove the steering column opening cover.
  1. Remove the upper and lower steering column shrouds.
    1. Remove the three screws.
    1. Remove the lower steering column shroud.
    1. Remove the upper steering column shroud.
  1. Remove the multi function switch.
    1. Remove the two screws.
    1. Disconnect the electrical connectors.
Installation
  1. NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
2010&c18=modelyear&c20=n130593&c35=wsm%2cmultifunction%20switch%2cswj%2c211-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 08, 2011 | 1998 Ford Expedition
How to remove my key lock 2000dodge caravan
Ignition Lock Cylinder - Removal & Installation CAUTION The Supplemental Inflatable Restraint (SIR) system must be disarmed before working around the air bag or SIR wiring. Failure to do so may cause accidental deployment of the air bag, resulting in unnecessary SIR system repairs and/or personal injury.
    Fig. Depress the retaining tab to remove the key cylinder
To install:
  3. Align the ignition lock cylinder with the grooves in the lock cylinder housing. Push the ignition lock cylinder into the housing until the retaining tab sticks through the opening in the lock cylinder housing.
  4. Turn the ignition key to the OFF position and remove the key.
  5. Install the lower steering column shroud and install the mounting screws.
  6. Place the lower steering column cover into correct position on the lower instrument panel and engage the clip that secures the right side of the cover to the instrument panel.
  7. Install the lower steering column mounting screws.
  8. Install the mounting screws that hold the parking brake release handle to the instrument panel.
  9. Reconnect the negative battery cable.
Hope helps (remember rated and comment this).
Aug 11, 2010 | 2000 Dodge Caravan
Need to replace the ignation switch in my 2000 chrysler LHS
  1. Disconnect negative cable from battery.
  2. Remove the Instrument Panel Center Bezel, Chrysler and Dodge.
  3. Remove side trim panel to steering column cover.
  4. Remove the screws that secure the steering column cover to the instrument panel and relocate panel.
  5. Pull the steering column cover rearward at the top and right side of the cover to release the snap retainers from the instrument panel.
  6. Remove the screws that secure the instrument panel steering column cover reinforcement to bracket and remove reinforcement from the vehicle. Remove the 2 front mounting nuts.
  7. Remove the lower mounting nut.
  8. Slide the assembly rearward into the instrument panel and down to gain access to switch.
  9. Disconnect the electrical connector from the ignition Switch and SKREEM Module.
  10. Remove the interlock cable by depressing the locking tab and pulling straight.
  11. Remove ignition switch mounting screw.
  12. Squeeze the 2 locking tabs to remove ignition switch from the lockhousing .
Removal and installation of the ignition switch
To install:
NOTE A tab on the ignition switch indexes to a notch in the lock cylinder housing. Also, a slot in the end of the ignition switch fits over the shaft in the end of the lock cylinder housing.
  1. Use the ignition key to rotate the lock cylinder to align the ignition switch with lock cylinder housing.
  2. Insert ignition switch into lock housing until locking tabs are seated into openings on lock housing.
  3. Install ignition switch mounting screw.
  4. Install the interlock cable into the switch assembly. Attach electrical connector to SKREEM Module.
  5. Install switch assembly into Instrument Panel.
  6. Attach electrical connector to ignition switch.
  7. Tighten the 2 mounting nuts.
  8. Tighten the lower mounting nut.
  9. Install steering column reinforcement.
  10. Steering column reinforcement installed.
  11. Install the Steering column reinforcement cover.
  12. Install trim panel end.
  13. Install the Bezel cluster.
  14. Install the ignition switch bezel ring.
  15. Connect the negative battery cable.
May 28, 2010 | 2000 Chrysler LHS
Install a Ignition lock cylinder 1997 Pontiac Grand Am
  • Ignition Removal Instructions
  • Disconnect the negative battery cable from the battery. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • Remove the upper and lower shrouds. Refer to Steering Column Trim Covers - Disassemble - Off Vehicle or Steering Column Trim Covers - Disassemble - Off Vehicle .
  • Put the key in the steering column lock cylinder set (1).
  • Turn the key to the "START" position.
  • Install a 1/16 allen wrench (2) into the hole on top of the lock module assembly in order to release the steering column lock cylinderset retaining pin.
  • Turn the steering column lock cylinder set (1) into the "RUN" position.
  • Pull the steering column lock cylinder set (1) out from the lock module assembly.
  • Remove the key from the steering column lock cylinder set (1).
  • Installation Instructions
  • Insert the key into the steering column lock cylinder set (1).
  • LIne up the locking tab (2) and the positioning tab (3) of the steering column lock cylinder set with the locking tab slot (5) and the positioning tab slot (4) in the lock module assembly (6).
  • Push the steering column lock cylinder set (1) into the lock module assembly (6).
  • Rotate the steering column lock cylinder set (1) in the lock module assembly (6) into all positions.
  • Install the upper and lower shrouds. Refer to Steering Column Trim Covers - Assemble - Off Vehicle or Steering Column Trim Covers - Assemble - Off Vehicle
  • Remove the ignition key from the lock cylinder set (1).
  • Connect the negative battery cable to the battery. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical
I hope this helps and good luck.
Please remember to vote 962e1fb.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | 1997 Pontiac Grand Am
How to remove the battery from lenovo T61 and put it back in?
the instructions below are from the owners manual page 69. you can download the manual with accompining pictures to guidr from the link below: ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/42x3547_04.pdf
Table 11. Removal steps of battery pack Unlock the battery release lever 1. Holding the battery release lever in the unlocked position 2, remove the battery pack in the direction shown by arrow 3. 312 When installing: Install the battery pack along the slide rails of the slot. Then make sure that the battery release lever is in the locked position
I;ve spent my time to solve you're question, please show the good grace to at least take a few seconds to rate this answer.
Feb 01, 2009 | Lenovo ThinkPad® T61 PC Notebook
Minitor V
The problem is... the features are software programable. An owner's manual would be of little help. You need to talk to the Tech or Service Co. that originally programmed the pager.
Geno
Jan 23, 2008 | Radio Communications
Motorola Mobility Q Logo
2,017 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
