Question about Royal SC180MX Shredder
Shredder often won't run. It just beeps - Royal SC180MX Shredder
    Genius:
  • 1,218 Answers
Try cleaning the "eyes" in the middle where you insert the paper, have you ever lubricated/oiled the cutting blades????
If neither of these remedies work you may need parts...you can contact Royal at 1-800-524-0799.
Posted on Oct 14, 2010
Beeps and stops; doesn't stop when empty
As for your first part - It sounds like there is something wrong with the switch lever that moves to complete the electrical circuit to start the shredder. On every shredder I have seen, there is a little "bellows" linked up to this lever that pushes it back so the machine will shut off. Most of the time all you have to do is put another piece of paper in and let that get shredded and the shredder will stop afterwards. If not, then just use the main switch to turn the shredder off.
Second, the beeping during "mid-shred" sounds like a warning that the shredder is starting to overheat and shut down. If this is the case, just wait a few minutes to allow it to cool down and try to finish the shredding you have. I have found that if you feed a shredder a constant stream of paper to shred, this might cause the shredder to overheat.
Also, the shredder may get overloaded with pieces of the shredded paper. Here is the way to check on that:
1. UNPLUG THE ELECTRICAL CORD FROM WHEREVER YOU HAVE IT PLUGGED IN.
2. Lift the shredder from the bin and turn it upside down.
3. Look for an excessive amount of paper in the bottom of the shredder. If there is a lot, you can remove it in several ways. (Most likely the bin is quite full at this point.) Pull the majority of it out and put it in the bin. If there are pieces of paper that you can pull out with your fingers, use a tool (needle-nose pliers, serrated tweezers, a hemostat, etc.) to get those difficult pieces out.
Replace the unit on the bin making sure that it is the same way you took it off. In most cases (on the better shredders), there is a notch on the underside of the shredder that needs to be on top of a "nub" that is on the edge of the inside top of the bin. Unless that nub is aligned with the slot, the shredder will not work.
Apr 26, 2014 | Staples ID Armor IDX50B Shredder
Shredder Green light won't come on and won't shredd. won't go in reverse either.
I had the same problem with the same shredder. The unit uses mains voltage which is rectified to DC and eventually feeds two 12V zener diodes wired in series for a 24Vdc supply. These are 1N4742A (Radio Shack 276-0563), 1W parts. They overheat and will short, which you can verify with a VOM. I reassembled the unit, but recall they are away from the relays at the tail end of the large white colored power resistors, side by side in the same direction. I think Z1 and Z5. After replacing these parts, green LED and reverse, etc. will work.
Apr 14, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Shredder won't stop running
THERE MAY BE SOME PAPER SHREDS BLOCKING THE LASER LIGHT.
UNPLUG SHEDDER AND CLEAN CUTTER HEADS.
Sep 30, 2011 | Office Depot Ativa DQ60M Shredder
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Jun 04, 2011 | Royal VF1012mx Shredder
My royal sc120 shredder will light up but there is no sound will not run. I have cleaned out clogged bits of paper. What could be wrong?
Shredders have a reputation for being very unreliable...they often just quit like that...
You can try also to blow it out with a can of compressed air, but it probably won't help... not much else that you can do...
heatman101
May 27, 2011 | Royal Sc120 Shredder
Have a new electric shredder does not have
Brand new shredder with no owners manuall I plugged it in.it won't start is there a first time procedure t o use it
Jul 10, 2010 | McCulloch Electric Chipper Shredder
Shredder Beeping
The motor would always turn the cutters.
You likely have a broken chain or a loose gear on a shaft. If you hear the motor running and the cutters are not spinning something in the drive is broken. Likely the chain.
hope this helps.
Mar 20, 2009 | Dahle High Security 20634EC Shredder
Universal Shredder 38016
Sounds like the pcb is faulty.Get a new board or a new Shredder. Dave UK
Feb 22, 2007 | Universal Office UNV-38016 Shredder
Royal SC180MX Shredder Logo
257 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
