Question about LG 42LC2D 42 in. LCD HDTV
I have a toshoba lcd tv mod 42rv535u that has no back light. I ck the power supply and all voltage is good. I also put in a new inverter still no light.The set will come on and i get snd but no pix. if i put a light on the screen i can see a pix. Any help?
  • patmac2 May 04, 2010
    Could i have a bad power supply? I did ck all voltages but a couple of heatsinks was cool.
  • patmac2 May 06, 2010
    That sounded like a good answer and thank you.
    Pat
  • LG Master
  • 12,061 Answers
Http://www.scribd.com/doc/22277758/Toshiba-TV-LCD-Training-32wl36p
http://www.retrevo.com/support/Toshiba-42RV535U-TVs-manual/id/22963ag211/t/2/
http://www.service-manual.net/ashop/catalogue.php?cat=244&exp=&resultpage=48&shop=1
Hi at the very TOP, above find a Training & Service Manual This will give you great assistance. next is a user manual, a must have, and under that is a pay for Service manual, a MUST have .
Now with your "Backlight" problem. Think of a backlight, as really just a Lamp, it only has two connections, a bit like a Fluorescent tube, the "Inveter" simply steps up the voltage, from what is supplied to the "Input" to a much, higher voltage to run the "Lamp" You are going to have to find out, what that Voltage is, see if it is correct, as i wonder if indeed it is even there? If it is, you need to measure the Output of the "Inverter" with a High Voltage Probe/meter,and see what it's putting out, you see, even though, you replaced that, Inverter, perhaps the "Fault" destroyed it as soon as power was applied? You need to check, you absolutely need a Service manual for your exact unit, I could only find pay for ones, but you MUST get one, you simply cannot, repair this unit without, as you also must after repair use the service menu to restore defaults and setting again.
IF you wish to try to fix it yourself, and I do not recommend it without a service manual, So,. FIRST, you Must get a service manual, then you need, equipment, an Oscilloscope is a MUST HAVE.(may possibly be done without, if NO alignment, or pattern observation, is required). Also a Multimeter, and soldering iron, a DE-soldering station, an anti-static wrist strap, (Any TV is extremely static sensitive). Now FIRST you must make sure the Power supply is 100% as if this is NOT then nothing else can be. Also there are safety considerations, any unit that can cause a Fire or Explosion, or both, needs to be attended to with the utmost care. As if it isn't done correctly, a catastrophe is indeed possible, Faulty sets can cause a fire, and a fire in the middle of the night, I believe is not good. And any person that has attended that set, will be held to account. Now with that understanding, I guess proceed if you wish.
Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL. So the very first readings you need to make are on the Power Supply, check each and every voltage, and work out from there, but now you have your user manual, it should be easy... just follow the troubleshooting steps within.
Now if you feel that it you do not want to do it. It is my professional advice is to get you set looked at by a Toshiba Authorised Service Centre, and ask for free "Quote", this way, you will be able to make an informed judgment, as to repair or replace. As these days seemingly insignificant SYMPTOMS, often cost as much to repair as it may cost to buy.
Posted on May 05, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the issue is with backlight as you have already replaced the inverter. It could also be due to the inverter circuits for the backlights. If circuits are fine then the inverter board is required to be replaced. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is in off position. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 04, 2010
Vizio logo does not light up amber when plugged in but turns white when power button is pressed. no picture or sound. Big Transformer on power board makes a light buz sound when plugged in also.
1. When the TV powered up, please measure the 24V, 12V & 5V are there, if one voltage is missing, you may have a defective power supply.
2. If the power supply lost the 24V source, you may unplug the power supply connector on both the inverter board, then power it up, if you got the 24V back, you do have a defective inverter board, you may unplug them one at a time to locate the bad one.
3. If the power supply & inverters are good, you may have a defective main board. The common problem on the main board is that a voltage regulator is bad, you may use your millimeter to measure them 1 x 1. The out put voltage (on the heat sync) should be 1.25V + the control voltage (Pin 1), for example: if the control pin voltage is 0, the output voltage should be 1.25V, if the control voltage is 2.05V, the output voltage should be 3.3V, if one of them is out of range, replace it, you may find the part from Digikey Co. The part number printed on the regulator is AMC1117.
Apr 08, 2015 | Vizio VX42L 42 in. LCD TV
Where is other Back Light Inverter Board ?
Some sets only have one board.
If you are having problems with no backlight, you also need to check the power supply which powers the backlight circuit. Usually it is 24 volts, so check for that as well.
If everything checks out fine, also remember that the backlight itself can go bad.
Nov 07, 2013 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Backlight Inverter Repalced still not working
dim the lights in the room, turn on the set, and shine a bright flash light on the screen. Do you see a faint picture? Also be advised that there are a lot of bad parts floating around on EBay. No backlight condition could be cause by a bad main board, power supply, inverter board, high voltage short on the inverter output, or a bad backlight bulb.
Toshiba Regza 42RV535U42" LCD HDTV when i turn it
Check the power going to the inverter board (24V) if ok...replace Inverter board....
Oct 28, 2013 | Toshiba Regza 42RV535U 42 in. LCD HDTV
My samsung tv replace the power supply board. got sound no pictuer replace the backlight inverter stell no picture
You have to check whether the back-light inverter gets its proper voltages to function. There as many voltages that controls the back-light inverter. Check these is a skilled work. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 23, 2013 | Samsung LN40A650A LCD TV
VIZIOP42HDTV10A . It hadn't picture mean black screen , but hear sound from every channel and all another devices input
hi, Your tv has problem with its back light inverter stage. All LCD TV have back light to illuminate the pixels. There are two types of back lighting CCFL(Cold Cathode Fluorescent Lamp) and LED. In your tv its ccfl. As it is ccfl it need a high voltage above 1000v. To provide such a high voltage there will be an inverter stage in all lcd tv with ccfl back lighting. Normally in LCD tvs there will be three boards such as Mother board , Back light inverter board, and power supply. In your tv the ccfl back light inverter stage is faulty. There will in inverter transformers in the inverter board. As it is high voltage transformer there is possibility of its winding get shorted. If so it will drain a high current from the power supply and the protection circuit will shut down the voltage to the inverter board. check the inverter board first. Also there is possibility of bad electrolytic capacitors in the inverter board will lead to this type of problem. First of all check the supply voltage from the power supply to the inverter board. Change the electrolytic capacitors in the inverter board and in the power supply stage. If the problem is not rectified then you have to replace the inverter board. ok
Jun 10, 2011 | Vizio P42HD Television
Tv flickers off and on
You have to check the back light inverter of your lcd tv. In all lcd tvs there are back lights to illuminate the pixels. There are two types of back lighting in use . CCFL ( cold cathode fluorescent lamp) and LED (light emitting diode). In you your tv it will be CCFL. If it is CCFL then it need an inverter (voltage step up circuit) for getting its working voltages. Normally it will produce above 1000V in low current. In the inverter circuit there will be inverter transformers. If the winding of the transformer get shorted then the inverter will drain a high current from the power supply. If so then the current sensing circuit senses the same and it will shut down the power supply. That's why it do the cycle ON an OFF repeatedly.
Just check the inverter board. Normally there will be three circuit boards in LCD TV. Mother board, SMPS (switch mode power supply) and inverter board. In some tvs the SMPS and inverter bord will com-pained as one board. you have to check the inverter transformers. there will be 4 or 6 inverter transformers. if available replace the inverter board as a whole.
Also check the electrolytic capacitors in the power supply. if any of the capacitor seems like one that in the picture, then replace the same and then only go for the inverter board
ajin_g_8.jpg ok
May 29, 2011 | LG 42LC2D 42 in. LCD HDTV
Toshiba 42RV535U again. I detected 3.6V at AC DET and 2.9V at Power Sig pins on the power supply board, instead of the 2.9 AC Det and and 3.2 Power Sig specified in the 42RV535U service manual. Could this...
Are you blowing any fuses - if not, good. Hopefully nothing is shorted. Inspect the power board thoroughly for bad capacitors - look for bulging. Inspect the circuit traces for cold solder connections. Also, check the Zener diodes for a voltage drop - one of them may be bad. I don't think the inverter board is bad. I think you're on the right track - THINK!
Jan 21, 2011 | Toshiba Regza 42RV535U 42 in. LCD HDTV
My Toshiba 42RV535U LCD television will not turn on. No LED lights when plugging in, tried a known good plug.
If you have no indicator in the front at all, it means that the 5vdc standby power supply is not working, it needs this voltage for the TV to start up. Please read my guide to understand more.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 14, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
49 people viewed this question
Computer Repairing
Computer Repairing
